RUN Command for BS2 SX
·I just got a· BS2 SX OEM Kit·· Could some one tell me what you would use the RUN Command for· And how you would use it
Could some one give an example of a routine that would be easier to use the run command
Please use the same routine for both example· a real simple routine
Basic Stamp··
Basic Stamp SX
I want to understand how you would use this command
I ran the example in the Basic Stamp Editor but I do not really understand the example
·I want·an every day use example
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 5/29/2009 7:49:49 PM GMT
Basic Stamp··
Basic Stamp SX
··Thanks for any·
·that you may have and all of your time finding them·
Sam
A throwbot project would run program 1 to initialize the sensors and servos, then determine if it was right-side-up, upside down, or on its side, then run a different program depending on its orientation in order to right itself before running the program that tells it to begin moving somewhere... I haven't actually looked at the Tickle Me Elmo that rolls around on the floor, but it *may* use something like this with whatever controller it employs to always get itself standing again after rolling on the floor laughing.
::remembers that I have to get one of those to tear apart - evil grin -::
Anyway - that's what the RUN command is for. If you're only used to running BS2 programs, you'll have to do a little reading to get the low-down on using the BS2sx.
Dave
Thank for your example of how you might use the RUN Command
··Thanks for any·
Sam
This doesn't pertain to your subject, but just word to the wise. You might need to compress your subject title's down a bit. Typically, when someone is scanning the list of forum subjects, they(I especially) tend to skip over the long, drawn out subjects. For example, if you make your subject "RUN Command for BS2", you might get more responses and help. I just mean this as a tip from my own experience.
Thank for the tip
··Thanks for any·
Sam
