Best way to measure voltages above 3.3
Hello all,
·Just received my new propeller and have been playing with it a·bit. I have an application where I would like to measure voltages from 14.4 VDC·down to 10.5 VDC. Can this be done using the internal ADC's or would I be better off using an external chip. If external what would be a good choice? I need about .05 volts resolution.
Some sample code with be great also.
Thanks for the help
Patrick
·Just received my new propeller and have been playing with it a·bit. I have an application where I would like to measure voltages from 14.4 VDC·down to 10.5 VDC. Can this be done using the internal ADC's or would I be better off using an external chip. If external what would be a good choice? I need about .05 volts resolution.Some sample code with be great also.
Thanks for the help
Patrick
If you only want to measure a single voltage, you could go with the ADS7816 from TI. You can get a few as free samples, for tinkering, and there is code already for it. The code requires a cog, but samples 200,000 samples per second and does a running average, or allows you to grab individual samples. It's not in the OBEX, but I can post it if you want. Oh, this is a single channel, 12-bit ADC.
Another chip is the TLV2543 from TI. It's a 11 channel, 12 Bit ADC from TI. Again, free samples and a SUPERB driver written by Tim Moore. This driver requires a cog, but samples ALL 11 channels at about 4,000 samples per second and does a running average. The code for this is in the OBEX.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=2556350&keywords=IC%20Digital%20Pot&stock=1
Post Edited (Bill Drummond) : 5/28/2009 10:50:33 AM GMT
Kudos to Tim Moore!
