When a pin is used as an input can it take 5V?
Sorry to ask this question again, but I'm having trouble understanding the difference between a pin used as an input to look at a 5V line and a pin with a resistor in front of it to look at a 5V line.
Why is a resitor needed if the pin is an input? Since there's no current flow, no voltage is dropped across the resistor and thus it doesn't really do anything.
Thus,·is a resistor needed or not? I hear that putting 5V on the propeller chip's pins will break it but when the pin is in input mode it shouldn't matter.
Thanks, for helping to clear this up.
Nyamekye,
Nyamekye,
Some chips have a different circuit, with "5 volt tolerant inputs", but that is not the case with the Prop.
Tracy Allen
www.emesystems.com
So, I should use a resistor value of 120 ohms or greater to keep the current below 40mA? I plan can use 240 ohms however instead.
Also, should I worry about this for 3.3V inputs, or will this not be a problem?
Nyamekye,
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
The relevant info is published; it's in the datasheet. As stated there, the maximum current allowed through the protection diodes is +/-500uA. That implies a series resistor of 2.2K or more to protect against a 5V input.
Tracy Allen
www.emesystems.com
Nyamekye,
(Trying to cut down parts on a design, that is why I am asking these questions).
Nyamekye,
--Steve
Many times I have given the same solution:
www.sparkfun.com/commerce/product_info.php?products_id=8745
This absolutely takes the guesswork out of the picture. Use it and move on to other problems.
JMH
