Housing for projects
A couple of weeks ago I came across some housing that requires no mechanical (post)processing.
It is a DIN-rail mounted housing manufactured by Wieland
http://www.wieland-electric.de
I designed a pcb for it.
You can find more info on the housings (called WEB-housings) in the attached zipped datasheet.
The pictures show how the pcb's slide into the housing (so the pcb's requires no mounting holes).
The housing I used (size 8) can hold 2 pcb's. The top pcb could hold a LCD which would be protected
by the transparent top cover. The pcb size is 93x89.6mm
If anyone knows of other housings that are as easily handled as these, please tell.
regards peter
regards peter
I have used Jiffy Boxes but they have to be laser cut for openings [noparse]:([/noparse]
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
· Search the Propeller forums (via Google)
then it is quite affordable. I order them from Conrad Electronic
for € 7,29·(incl. VAT). (Conrad product ID·523780)
regards peter
Thats a neat enclosure. Some years ago I used Erni enclosures, but would have to cut holes for RJ45 jacks etc. That one you at least have a chance of doing the external connectors without modification (as you have shown). I like the clear lid.
Price on the Erni was similar.
Nice board btw
tubular
I now also have a top pcb. It holds a display, rtc+battery,
and a umFPUv31 (+ optional MAX487) which gives me 2x Analog In (12bits), 2x digital out (turned into
100mA OC outputs) and a buffered bidirectional uart that can be converted to rs485.
regards peter
Post Edited (Peter Verkaik) : 6/30/2009 6:15:48 PM GMT
It's Only A Stupid Question If You Have Not Googled It First!!
http://www.conrad-international.com/
and type 523780 in quicksearch
That will bring up the productpage.
It also lists some variants (smaller housings).
Dependant on your residence, you can try
http://www.conrad.com
and select your country.
regards peter
I have ordered a couple of extra large cases for some LED displays. Mark does an excellent job with detail and very reasonable compared to what others would charge for a custom case. I actually got to meet him too as he lives not to far from·some of my in laws·near·Cleveland, OH.
Attached are some measurements that I used for my pcb
for the 89.6mm wide case.
Besides the connectors shown, there is enough 'connector' space
to hold·a VGA connector, RJ11/12/45 and USB and PS/2 sockets as well.
regards peter
Post Edited (Peter Verkaik) : 8/17/2009 3:55:30 PM GMT
What am i missing. Do they not do business with the USA?
Only via conrad_international.
You can try Wieland_USA directly.
http://www.wieland-electric.de/company/locations/usa-wieland-electric.html
WEB housings
http://www.wieland-electric.de/products/appliance-terminals-electronic-housings.html
Sales
http://www.wieland-electric.de/sales/searching-for-addresses.html?tx_ffaddresslist_pi1%5Bcountries%5D=220&tx_ffaddresslist_pi1%5Bregions%5D=&tx_ffaddresslist_pi1%5Bzip%5D=
For Arizona
Arizona Components
2901 W. McDowell RD
Suite 1
85009 Phoenix, AZ
Phone: (602) 269-5655
Fax: (602) 269-6375
Master Distributors
2425 S. 21st Street
85034 Phoenix, AZ
Phone: (602) 267-1111
Fax: (602) 267-7070
Piatt Sales
3310 West Bell RD
Suite 191
85053 Phoenix, AZ
Phone: (602) 978-2286
Fax: (602) 978-4529
mike@hartlandsw.com
S&S Technologies
Jack Radavich
5900 N. Granite Reef Rd.
85250 Scottsdale, AZ
Phone: (480) 609-9390
Fax:
www.sstech.com
regards peter
Post Edited (Peter Verkaik) : 8/17/2009 4:00:04 PM GMT
49 International Rd.
Burgaw, NC 28425
Phone - 910-259-5050
Fax - 910-259-3691
salesUSA@wielandinc.com
You can try the above as well.
regards peter
http://www.onlinecomponents.com/buy/WIELAND-ELECTRIC/87.080.0053.0/
87.080.0053.0 is the Wieland productnumber.
regards peter
www.polycase.com/item/ek-50.html
Andrew Williams
WBA Consulting
