basic stamp thermostat project
Hello,
I seem to be having some difficulty writing code for my thermostat project. What i am trying to do is, when one of the momentary contact switches (pushbuttons) gets closed, it will send the user to the proper sub program. The stamp does not like the line directly beneath the 'do'. I have a switch (and resistor) wired up from Vdd to pin 4 (Coolpin). I'm not sure what syntax rule i'm breaking. Am i not allowed to use 'high' in this fashion? If not, what would be a better way of going about it?
DO
IF CoolPin = high THEN <
PAUSE 500
GOSUB cool:
ELSEIF HeatPin = high THEN
PAUSE 500
GOSUB heat:
ELSEIF ReturnLCD = high THEN
SEROUT lcdpin, baudlcd, [noparse][[/noparse]"Invalid"]
PAUSE 500
GOSUB main_menu:
ENDIF
LOOP
Thank you,
Scott
DO
PAUSE 500
GOSUB cool:
PAUSE 500
GOSUB heat:
PAUSE 500
GOSUB main_menu:
ENDIF
LOOP
Thank you,
Scott
DO
IF CoolPin = 1 THEN
PAUSE 500
GOSUB cool:
ELSEIF HeatPin = 1 THEN
PAUSE 500
GOSUB heat:
ELSEIF ReturnLCD = 1 THEN
PAUSE 500
GOSUB main_menu:
ENDIF
LOOP
I wired from Vdd to a pushbutton, and from that side of the button i ran a 220 ohm resistor to p4(coolpin) and 10k resistor to ground. It still does not seem to recognize that the button was pressed. Any ideas?
Thanks again
Welcome to the Forum
Let get your menu to work first before we do any thing else
Look_Here··at page 90 it show how to wire up a switch to a Basic Stamp Pin
If you have· wired it right you should see which ever button that is pushed with that routine in the DEBUG screen
Once you get this to work then move on to the next thing would be to write you heat and cool routine
Try this routine and see what you have
' {$STAMP BS2}
' {$PBASIC 2.5}
coolin·· ·PIN··· 1········ ' Use·the pin # that you have the switch wired to
heatin·· PIN··· 0········· ' Use·the pin # that you have the switch wired to
'·You could just use one switch to switch between routine but if you· did that then your IF THEN·ELSE THEN statements would be just a little different
·DO
PAUSE 500
DEBUG CLS
DEBUG HOME, ? coolin, ? heatin
IF Coolin = 0 THEN················· ' You may need to·change this to "0" instead of "1"
GOSUB cool:
ELSEIF Heatin = 0 THEN
GOSUB heat:
ENDIF
LOOP
Cool:
DEBUG CLS
PAUSE 500
PAUSE 500
RETURN
heat:
DEBUG CLS
PAUSE 500
DEBUG HOME, ? heatin
PAUSE 500
RETURN
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 5/26/2009 10:59:41 PM GMT
Thanks again, folks
Scott
I started by changing the pins to PIN format vs. CON. Not sure if that affected the outcome, though
You can use·coolin· PIN·· 0·· OR···· coolin··· ·CON··· 0········ ·ether one will work
If you leave a pin FLOATING·that you are going to use as an INPUT it will stay at a "1" or change back and forth " 0 " to a " 1 "
I have one suggestion for you is when you use a switch or switches to change routines
You need to test the routine with the switch or switches with ·something·like·what I have in the example that I gave you
so you can see if
One .....>>>> You have your switch or switches working or not
Two .....>>>> You should use the DEBUG command to debug your code Routines to see if they are working right or not
Three .....>>> Once you have your Menu working set it a side and just work on the Cool Routine get it working right
···················· Then work on the Heat Routine and get that work right
····················· Then work on the rest of the routines then put it all together
Four .........>>>·When you have let say the cool routine·and the heat routine working and all other that you are going to use·make
······················them·a·SUB··ROUTINES and call them up when you need them
····················· It take less memory space doing·it that way·and easyer to follow your own ·code
These are only suggestions and what·I have here is how·I write my·the code routines
In the Attachment bellow·is a project that I had a lot of trouble getting some routine to work right
I had to·trouble shoot why it was not working· right with DEBUG Statements
I hope this helps
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 5/27/2009 12:59:56 AM GMT
Yes it take time this project took·about three week working on it 4 to 6 hour a week
What i do also is save your routine that you make and keep them they come in handy latter in other projects
··Thanks for any·
Sam
I've got most of the code written for the heat / cool functions. They work well enough. I do however want to add the ability to turn the backlight of the LCD screen off after a certain period of time (3-4 seconds).
I used a FOR...NEXT loop in some areas, like the main menu, since it simply loops through over and over, and nothing changes. But I realize that I won't be able to do this easily in the change temperature subroutines, since the program doesn't follow a straight path through the code.
I then considered using a makeshift timer outside of the program, like an RC circuit, coupled with a diac and SCR. Problem is, I don't think they make diacs with breakover voltage less than ~20V. If I could find one @4V or so, compatible with the stamp's 5V HIGH state, I think it would work.
My question is, does anybody have any other strategies for starting and stopping a timer sequence, within or outside of the Pbasic program?
I have a sample of my cool routine below, thanks guys!
Scott
Cool:
GOSUB BLon 'turns backlight on
PAUSE 250
DO
' HIGH timerstart
' HIGH timertrig
' LOW timerdone
'Considering an RC time ckt here, hopefully turn the timer on and off at will, regardless
' IF timerdone = 1 then
'of where the program is currently looping
' GOSUB BLOff
' LOW timertrig
' low timerstart
' endif
GOSUB read_ds1620: 'takes temp
GOSUB ClearLCD
GOSUB ChangeSetPt
SEROUT lcdpin, baudlcd, [noparse][[/noparse]"SetPt=",DEC setpoint,2,"F-", "Cool",149,
"Temp is ",DEC temperature,2,"F" ]
IF temperature > setpoint THEN
DO WHILE temperature > (setpoint-5)
HIGH 15 'turns on fan
GOSUB READ_ds1620: 'reads / converts temp
GOSUB clearLCD
GOSUB ChangeSetPt 'allows to change setpoint on the fly
SEROUT lcdpin, baudlcd, [noparse][[/noparse]"SetPt=",DEC setpoint,2,"F-", "Cool",149, 'shows stats on lcd
PAUSE 150
IF Auto = 1 THEN 'exit button
LOW 15 'shuts down fan
PAUSE 200 'waits 1/4 sec
GOSUB main_menu: 'returns to main
ENDIF
LOOP
ELSE
LOW 15 'turns fan off
ENDIF
LOOP UNTIL Auto = 1
GOSUB main_menu
Post Edited (thikyela) : 6/12/2009 1:31:37 AM GMT
So now I'm off to try and find a way to lock down the thermostat, using a keypad maybe? Or a biometric security device, maybe a fingerprint reader, or voice recognition? I know that might be overkill, but I'm just having fun with it. I know when i was young I'd crank that heater up to 82, then go shirtless. Not gonna let that happen....
