BS2 and servo
Hello all wise ones,
I'm have a Parallax continuous rotation servo running for a little game I've created (controlled by a BS2).
The only problem is the servo pulses when I power up my application.
Is there a way to prevent the servo from moving/pulsing when I power up my system?
Shmow (less than wise)
Just so I am sure of the connection you recommend - I connect this resistor from the BS2's control pin to ground in parallel with the servo? Did I get that right?
Shmow
