Is my Datalogger DOA?
Should the Datalogger show any sign of life when it is powered on, regardless of whether I'm trying to talk to it, or whether a flash drive is connected?
I'm working on a temperature control/logging application based on an Arduino. I've successfully hooked up an RTC, sensors, and a relay, and the Arduino seems to provide enough power for them all. But when I disconnected them and tried to hook up the Datalogger (#27937), I get nothing. I have wired it for UART and SPI mode, and even hooked up only Vss and Vdd, but I get no signs of life from the onboard LEDs that Parallax's docs say should be there.
I have let it run for a few minutes with no change. Is it likely dead? Is there something in particular I should try? Do any of the LEDs illuminate before the EEee sync process begins? Is this all covered in a datasheet that I missed?
Thanks for any assistance you might be able to render.
-Lauren
-Lauren
