FullDuplexSerial at 5bps
Is there any reason why the FullDuplexSerial.spin at obex.parallax.com/objects/54/ won't work at 5 bps? Seems like it should work at any odd baud rate....
Bad spellers of the world untie!
This is using a USB Pro Dev. brd. The usual debug using pin 31 and 30 to output what's coming into pin 1, so the prop. is a simple pass thru to a PC running Parallax Serial Term.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR BYTE Data OBJ ComputerConnection : "Debug_PC2" 'data connection to the PC HammerConnection : "FullDuplexSerialPlus" 'data connection to the Hammer PUB Main HammerConnection.start(1, 2, 0, 5) ' pin1 to recv - only to monitor traffic, pin2 not used. Need to change buad rate for diff. ECU. ComputerConnection.start(57600) waitcnt(clkfreq*2 + cnt) ComputerConnection.putc(ComputerConnection#FF) 'Form Feed Repeat CommunicateFromHammer UpdateVariables PUB CommunicateFromHammer ' monitor data from Hammer Data := HammerConnection.GetHex PUB UpdateVariables ComputerConnection.Str(String(ComputerConnection#TAB)) ComputerConnection.hex(Data,2) ComputerConnection.Str(String(ComputerConnection#CR))
Using another computer serially connected to the Pro Brd DB9 connection, all's well with 300, 600 etc. baud. I know of no terminal program that you can dial down to 5 baud (not my favorite RealTerm either) to check, but on my o'scope the 5 baud input looks as it should. I own a copy of Viewport, so I'll fire that up. Can you see anything amiss?
A certain initial 5bps address byte is sent on the "L" line to a certain control unit in the car.
Phil, you're correct, and this explains it....this isn't sent using a zero terminated string.
