Robotics and Rocketry??
So I'm new to this forum and robotics in general. Just to give an idea on where I stand, I have finished the book for the boe-bot and have been playing with some of the add-on sensors. While watching the history channel, I saw an old Soviet mobile ICBM launcher. Has anyone ever tried to apply this concept to a boe-bot sized robot using a model rocket? Use the Ping to find a nice, open area outside and launch a model rocket mounted on top? I figure make a sort of blast shield out of a steel sheet, maybe 26ga and mount that on top of the board with some standoffs. Mount the rocket on top of that. Has anyone here done anything similar? Any potential issues you can think of? As with any model rocket, a safety system would be important. Perhaps have the robot get to its launch site and wait for input from maybe an IR emitter? Has anyone ever tried anything like that? I guess it is just the kid in me that wants to see something like that in action.
I'd recommend that you do all your testing with some kind of nerf rocket launcher
or something of the like. That way false triggers aren't a huge deal.
1 - Black powder exhaust residue is corrosive, and will quickly destroy any exposed circuit boards. When we fly electronic altimeters or staging timers in high power "dual deployment" rockets, we have to seal the bulkheads between the electronics and the deployment charges, in part to avoid overpressures to the pressure sensor, but also to keep BP residue from corroding the electronics. If you're thinking about flying a model rocket from directly atop a BoEBot, you'll need to seal the BoEBot electronics. The blast deflector isn't going to properly keep BP residue from the circuit boards.
2 - A BoEBot by itself is far too small to be a stable launching platform for a model rocket (though it might work for a MicroMaxx!). Remember that when the wind hits the fins of the rocket as its sitting on the pad, it can push and twist with quite a bit of force. I just spent the weekend helping rocketeers at the National Sport Launch load their rockets onto the pads, and even in fairly light winds on Saturday, it took some effort to keep things in place properly. To pull this off, you'd need some kind of extensions coming out the sides, contacting the ground a foot or more from the BoEBot itself.
Finally, I'm not sure what you're hoping to accomplish with this, other than having a mobile launcher. I think it would be mighty difficult to do anything autnomous that was useful. Finding a large enough launch site would be a very difficult task requiring quite a bit of intelligence (heck, most people can't do it - that's why we join our local NAR chapters and fly from their fields). We're not talking about finding a five-foot diameter clearing. For an A motor, the minimum site dimension is 100 feet, and goes to 400 feet by the time you're flying C motors. You'll need a lot more than that if you want to get your rocket back. Finding the right spot on the field (e.g., far enough upwind from the inevitable trees) presents a second problem. And how would it check to make sure that the skies and range were clear (of airplanes and of spectators)? Or even that your Bot hasn't parked itself under a tree or a power line?
Now if all you're hoping to do is to put a rocket on a pad that has wheels and motors on it, and drive it out to the spot from which you're going to launch, here's a device that could easily be modified to do it:
http://www.vexrobotics.com/vex-robotics-vexplorer.shtml
It's discontinued, but there must be quite a few of them out there collecting dust. Put the launch rod and blast deflector out far enough on that arm, and you might even be able to use the video camera to get "pads-eye-view" launch video. There are no exposed circuit boards (though you'd still want to cover up the places where the wires connect), and it's heavy enough to provide a stable pad for A, B, and C motor-propelled rockets. I'm almost tempted to try this myself.
If you do try it, please be careful, and follow the NAR Safety Code as well as the local laws:
http://www.nar.org/NARmrsc.html
