New WIZNet Web Server Chip
Mike Huselton
I can't keep up. This page has an announcement for a new web server: www.saelig.com/miva/merchant.mvc?Screen=PROD&Product_Code=ICTCPEB001&Category_Code=
Salient features:
WIZnet Embedded Web Server Module (WIZ200Web)
Price:$31.74
Embedded Web Server module having Atmega128 & W5300
Operates as HTTP Server
Available of testing digital output (LED & LCD Control), digital input & analogue input through web browser
Guarantee system stability and reliability by using W5300, the hardwired TCP/IP chip
Provides Configuration Tool Program for easy configuration and control
Supports 10/100 Mbps Ethernet
RoHS Compliant
JMH
Salient features:
Price:$31.74
RoHS Compliant
JMH
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
This did force me to go back and check the pin spacings or pitch on the modules. The W5100 is closer than subsequent modules. Standard 0.1 inch pin spacing makes life so much easier.
So, maybe I'll use the W5300 module after all, even if it doesn't have SPI access. Other non-obvious features that I didn't grok at first glance makes me want to use the W5300 module.
The pin spacings I am referring to have to do with the WIZ830MJ module vs the WIZ810MJ.
JMH
Post Edited (James Michael Huselton) : 5/23/2009 11:38:34 PM GMT
www.tdswieter.com
Just kidding. I will volunteer for the job.
JMH
