BS1USB on USB Hub
When I plug the BS1USB into the USB port on the computer, it works fine.
But when it is plugged into a small USB hub, the program will not load.
The errors are show below. What can I do to fix this?
Tokenize successful. Download failed.
Hardware communications failure.
Fatal error on com port 25.
' {$STAMP BS1} ' {$PBASIC 1.0} Main: DEBUG CLS, "Hello World!", CR END
USBDriverInstallerV2.04.16.exe and rebooted.
www.parallax.com/tabid/530/Default.aspx
It has the exact same result. attached
The BS1USB board green LED lights up, but it is not recognized as a USB device.
The 4-slot Esense USB hub works fine with various (four) large USB drives and
(five) small flash drives, each from a different manufacturer and several with
various formats.
translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.e-sense.com.tw%2Fbig%2Fproducts%2Fproductdetail.asp%3Fid%3D447&sl=zh-CN&tl=en&history_state0=
Post Edited (humanoido) : 5/23/2009 9:49:22 PM GMT
Maybe the BS1USB won't work with any hub?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I currently use a powered one designed for notebook travel called a Kensington High Speed 2.0 powered USB hub and have never had a problem.
You may have an issue of·manually·pointing some or all of the set up to the appropriate port on the computer·that needs to be addressed but I've never had that issue. I do recall my computers port IDing themselves though. Good Luck.
The Esense USB hub derives its power from the computer - the link is posted above. The Stamp Editor will show that a port is selected. After that, it fails to communicate. I can run up to three full size USB Drives off this one hub. Does one BS1USB really draw more power than that?
Post Edited (Up4Days) : 5/26/2009 6:49:36 AM GMT
You may be experiencing additional latency by using the hub. Check your driver settings in the control panel to make sure that the latency timer is set to 1, not 16.
Still no change, same problem.
Dave
Dave Andreae
Parallax Tech Support·
It appears that the Esense USB hub is the problem therefore
I will use this hub for the larger USB drives and Flash drives,
and purchase a new hub, either the Linksys or Kensington
High Speed 2.0 powered USB hub. I think a powered version
is best as I plan to have all the slots filled.
humanoido
