SUPER TV B-GONE! A hilarious Recommendation for a Pranking BOE-BOT Project.
NinjaTech
Try this! A funny gadget which lets you turn off almost every TV! If you hack it up and·interface it to a MCU like the basic stamp or replace the connections of the switch and connect it to your BOE-BOT. You can turn off the TV and time with your BOE-BOT.
http://www.youtube.com/watch?v=v17o2itd-lU
I think I'm going to buy this kit·and interface it with my BOE-BOT.
It'll be hilarious to see a Ninja BOE-BOT turning off the TV.
Buy it here!
http://www.makershed.com/ProductDetails.asp?ProductCode=MKAD4
Buy it here!
First one to do this let me know!!!
P.S.
It has already been done with the arduino
http://en.wikipedia.org/wiki/TV-B-Gone
... If you follow it towards the bottom you will see firmware, which contains the power codes you need.
http://ladyada.net/make/tvbgone/download.html
http://ladyada.net/media/tvbgone/tvbgone11b.zip ... <-- NAcodes.c within this file is really all you need.
Thnx!
You will have to learn both the Arduino's C++ subset / libraries and the Stamp's PBasic 2.5 to translate between the two. It's possible to write a guide to how to do it, but there are a lot of details and it would be a lot of work to make such a guide.
There's another thread on an Arduino compatibility library for the Propeller, but it's still not a complete rote translation. You have to understand something about the program and the two languages.
the NAcodes.c file is the one im refering to
Im running windows 7
It's just a text file... open it with notepad. :-)
http://forums.parallax.com/showthread.php?92426-Adding-a-Background-UART-to-SX-B
http://forums.parallax.com/attachment.php?attachmentid=45693&d=1172896465
The SX-B...is basic code... Pretty easy to convert to BS2 code.
JonnyMac wrote some SIRC stuff for the Propeller back in 09' too.
