Bresenham ALGORITHM — Parallax Forums
Bresenham ALGORITHM
mxg331mxg331 Posts: 5
edited 2009-05-23 22:57 in General Discussion
I've built a memory·mapped VGA interface using the SX 48.· I've implemented many video functions such as Sprites, draw pixel, and draw box but the line has got me stumped. Does anyone know how to implement a line using the Bresenham ALGORITHM or otherwise?· Thanks!
Post Edited (mxg331) : 5/23/2009 12:28:41 AM GMT
  • LeonLeon Posts: 7,620
    edited 2009-05-22 22:13
    Don't you mean the Bresenham algorithm?
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • mxg331mxg331 Posts: 5
    edited 2009-05-23 00:28
    Yes, but any line algorithm will do.· I've already developed my own but it has many issues.
  • BeanBean Posts: 8,129
    edited 2009-05-23 02:04
    Here is one in SX/B
    ' Variables used by graphics subroutines
    cnt   VAR Byte
    cnt2  VAR Byte
    x1    VAR Byte
    x2    VAR Byte
    y1    VAR Byte
    y2    VAR Byte
    color VAR Byte
    Line SUB 4
    Line: ' (x1,y1,x2,y2) ; Set color before calling
      x1 = __PARAM1
      y1 = __PARAM2
      x2 = __PARAM3 - x1
      y2 = __PARAM4 - y1
      IF x2 >= y2 THEN
        cnt2 = x2 >> 1
        FOR cnt = 0 TO x2
          PutPixel x1, y1, color
          INC x1
          IF cnt2 >= y2 THEN
            cnt2 = cnt2 - y2
          ELSE
            cnt2 = cnt2 - y2
            cnt2 = cnt2 + x2
            INC y1
          ENDIF
        NEXT
      ELSE
        cnt2 = y2 >> 1
        FOR cnt = 0 TO y2
          INC y1
          IF cnt2 >= x2 THEN
            cnt2 = cnt2 - x2
          ELSE
            cnt2 = cnt2 - x2
            cnt2 = cnt2 + y2
            INC x1
          ENDIF
        NEXT
      ENDIF
      x2 = x1
      y2 = y1
    RETURN
    Bean
    There is a fine line between arrogance and confidence. Make sure you don't cross it...
    edited 2009-05-23 22:25
    Thank you for your response.· As I'm sure you can appreciate, the process I'm·implementing·is very time critical.· I would prefer (need) a line algorithm in SX assembly.· Thanks to all who are thinking about this!
  • JonnyMacJonnyMac Posts: 9,809
    Remember, SX/B compiles to Assembly and you may find that Bean's code works as well as you need. If nothing else, run it through the compiler and then take the output and see if you can optimize it (I do this a lot as it helps me learn Assembly).
