16 segment LEDs
I have been trying to find some documentation to that will show me how to connect and program a 16 segment display. So far I have found only bits and pcs that need to be cobbled together to create a whole understanding.
This document got me closer, but not quite there. http://www.maxim-ic.com/appnotes.cfm/an_pk/3212
Does an interface chip make it easier, along w/reducing pin usage
It would be cool if there was a driver in the OBEX too.
If you are using the Maxim chip to drive the leds you connect them as shown in table 1 and send data and commands serially as described in the chip documentation.
The major difference between the way the maxim chip drives the display and the way it is usually done is that they use Q0 - Q7 to drive the anodes (digit select) when they are high, and the cathodes (segment) when they are low. This allows them to multiplex 8 digits with 19 pins instead of the 25 pins (16 segments, 1 dp, 8 digit selects) it would take the old way.
BADHABIT indeed.
JMH
http://forums.parallax.com/showthread.php?p=790643
OBC also wrote one here:
http://forums.parallax.com/showthread.php?p=745806
Jim
Damn things take up alot of I/O, will def be using driver chips to cut that down.
How's that completed object coming along Mr. Savage?
The MAX6954 is on my list of "to buy" stuff for a project that's out about a month or so.
Jim
www.maxim-ic.com
