Low Cost RF Circuits — Parallax Forums
william chanwilliam chan Posts: 1,326
edited 2009-05-23 09:01 in General Discussion
I have always marveled at how the chinese managed to implement very low cost RF circuits for their remote control toys, doorbells and such.
I recently stumbled on a simple RF receiver circuit.
It claims to receive signals in the 27Mhz band but is without any crystal.
Can anybody explain whether such a simple circuit would work and whether it will be stable?
See attachment.
www.fd.com.my
www.mercedes.com.my
995 x 515 - 50K
    edited 2009-05-21 15:23
    I'm not an expert by any means, but this looks like a super-regenerative receiver. These do tend to "lock on" to the strongest carrier over a relatively broad frequency range and they're quite sensitive for the simplicity of the circuit. Have a look at the Wikipedia's article on "superregenerative".
  • LeonLeon Posts: 7,620
    edited 2009-05-21 19:06
    It is a super-regen. They have the disadvantage that they radiate interfering signals via the antenna, and don't have any selectivity to speak of.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • william chanwilliam chan Posts: 1,326
    edited 2009-05-21 22:01
    Why is the output capacitor (104 p) much larger than the antenna capacitor (4p) ?
    Can we use a PCB track as the receiving antenna?
    How long should the track be? and should we connect both ends of the track?
    www.fd.com.my
    www.mercedes.com.my
    Post Edited (william chan) : 5/21/2009 10:06:26 PM GMT
    edited 2009-05-21 22:12
    The output capacitor has to pass lower (i.e. audio) frequencies; therefore it has to be bigger.
    A PC track can work at UHF wavelengths but would not be adequate at 27MHz.
    edited 2009-05-22 09:39
    Is it better to wind yourself a 7 turns coil with 5mm core as suggested in the circuit
    or try to calculate the inductance and buy a complete inductor from Farnell?
    www.fd.com.my
    www.mercedes.com.my
    edited 2009-05-22 13:36
    Wind it yourself, I doubt if the inductors stocked by Farnell have a high enough Q. It's only seven turns anyway, and will only take a few seconds to make.
    Leon
    edited 2009-05-23 04:39
    From the schematic, it indicates a "slug", so you'll need to tune the circuit anyway. The L2 and C3 form an 'LC tank' that needs to match the desired frequency that you want to operate on.
    Beau Schwabe
    IC Layout Engineer
    edited 2009-05-23 08:41
    Sorry for being a newbie in rf circuits.
    How can I add an led indicator to this circuit to light up whenever it locks on to a strong signal?
    For a typical car alarm key fob that doesn't seem to use any external antennas, what frequencies do they use?
    www.fd.com.my
    www.mercedes.com.my
    Post Edited (william chan) : 5/23/2009 8:58:17 AM GMT
    You need to rectify the output and use it to turn a transistor on.
    Remote controls like that used to use 433 MHz here in the UK.
    Leon
