Keyboard issue with Propeller Tool
When using propeller tool with a belgian french keyboard on my toshiba notebook, propeller tool does not react as expected to typing special character using alt-gr.
Attachment shows the issue when typing the vertical bar with alt-gr 1.
With any program, I get a "|".
With propeller tool I get what is shown in the attachment: [noparse][[/noparse]superscript "-1"] and "|".
Get around is simple but boring: left shift, backspace, right shift.
What's the problem?
Can you fix it?
What's the problem?
Can you fix it?
spin
281B
On my Swedish keyboard I kan't get single $
With Alt-Gr.4 I get dual code ¥$ istead
Al other keys funktion correctly
Nothing is impossible, there are only different degrees of difficulty.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
- alt-gr "4" gives [noparse][[/noparse]Yen] anf "{"
- alt-gr "`" gives "``" after hiting space (dead key)
- alt-gr "´" gives "´´"...
- alt-gr "~" gives "~~"...
- alt-gr ";" gives a black box
- "§" gives nothing!
Again, this is typical to Propeller Tool; Notepad (or any other program) has the appropriate reaction!
In windows for each country you have a translation table, which translates the keys hit on the keyboard (which sends a so called scan code) to the ascii value. And that's what the keyboard driver also is doing. If you have a look at the end of the keyboard.spin you will find this table. Change it to your needs and post the result here, so that each belgian/french propeller-fan can use it.
The keyboard of my toshiba is defined as "belgian french" and works very well with any program, except the propeller tool.
As I said, when I type the pipe sign "|", (I have to type alt-gr "&") I get two characters on the propeller:
- a superscript "-1" that's coming from nowhere (not defined in any character tables)
- and the pipe character
You can allways erase that funny "-1" afterwards, but it's not funny at all!
Anyway, it was a great opportunity for me to go thru the keyboard.spin code
All others seem to work fine.
It used to annoy me but now I use BST on Linux[noparse]:)[/noparse]
no answer :-((
Nobody likes me :-((
HELP !!!
