Relay part number?
Can anyone give me a part number and a supplier for a good relay that will trigger easily at stamp output voltage levels?· I am currently trying to use a 9v relay by routing pin output to a base of a transistor.· Is there a relay that will work straight off the pin?
Dave
Dave Andreae
Parallax Tech Support·
The problem is that Relays are inductive devices and you wouldn't generally want to run them off your I/O pin directly. Besides being inductive they also generally draw more current than you want to have on an I/O pin. Using a transistor (or the ULN) is an inexpensive way to protect your BASIC Stamp Module.
Parallax Engineering
The·most I have ever used is 12 on a stamp (12 different stamp output pins) but only 3 were ever energized at a time.
Have a look at the following digikey number:
255-1403-5-ND
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=255-1403-5-ND
Alan Braford
Plasma Technologies
www.plasmatechnologies.com
