Reading Line Voltage
I need to read line voltage 100 to 125 vac what are some of the ways I can condition the voltage?
transformer·/ voltage divider
I will be using an ADC not sure which one yet I will see what I have on hand, 8 bit.
using Bs2 processor
I would like to read in one volt increments.
and yes I did a search and just had a hard time finding anything.
Larry
using Bs2 processor
Larry
Use a resistor voltage divider so that your adc will not be over-voltaged when the line voltage is at maximum.
As to resolution, an 8-bit adc gives you a count of 0 to 255. At 125 volts input, that should be 125/255 or 0.49 volts per count bit. The readings will be a bit twitchy without some additional filtering. I usually use a 12-bit LTC1298 which works nicely with the stamp and gives you a second channel as well.
Cheers,
Tom Sisk
http://www.siskconsult.com
I will try all my old wallwarts with a variac and do some testing
sounds like a great and cheep way of making this work quickly
and I just may be able to use the wallwart for stamp power also.
The isolation provided by the transformer in the wall wart, will also add a safety factor.
Make sure the output of the wall wart is AC and not DC or Regulated DC.
The·transformer output voltage·will rise and fall with the input voltage.
I also use the LTC1298 A/D chips and they are easy to use.
Math is not my strong point, so I have found that if you take 100 readings and divide by 100 you will get pretty close to the·actual reading.
Good Luck
Alan Bradford
Plasma Technologies
Canaan NH 03741
www.plasmatechnologies.com
It just dawned on me that you are reading an AC Signal. my read 100 divide by 100 works for noisy dc voltages (like you get with a plasma torch or welder).
To read an AC signal you need to get the RMS value (the value of DC that will do the same amount of work).
That we will nead a bit of help from some of the smarter members of the group.
Alan Bradford
Plasma Technologies
Canaan NH 03741
I'm looking at either using a amp to get 0 to 5 vdc or just scaling the ADC to read full scale at 2.5 or 3volts. I will check how low the the ADC will go.
Thanks everyone for the help
If the high voltage (AC) is transformed down to TTL level voltage(AC), Then Rectified to (DC) Then sampled 60 times a sec. and divided by 60. This reading or value would be the peak average.
All thats left is to multiply the peak DC average by .707 for the RMS value.
or Am I missing something?
________________$WMc%________
The Truth is out there············································ BoogerWoods, FL. USA
- Stephen
So you can sample 120 per second Add and Divide to get average, Multiply agian by 2 to get average Peek voltage then again by .707 to get average RMS value right?
Edited: Nope that won't work because it will average out to 0 never mind.
Post Edited (FearTurtles) : 5/24/2009 12:25:10 PM GMT
I assumed the NEG. half would mirror the POS. half. And from there an average of the POS. peaks / by .707 would give the RMS value After a set of samples was taking.
I know from working with welding machines that the reverse polarity half can far exceed the straight polarity half. But I don't see this happen here. I see the NEG half's just being the opposite of the POS. half's. in current flow, etc.?
Could You explain a little more in detail how My application posted earlier is off. I don't doubt that I'm wrong. I would just like to know what I did wrong in the Math?
___________$WMc%__________
- Stephen
Its more than obvious now that You have explained it.
With My method, I could get stuck somewhere below 90degrees(top of wave) from 0 volts and never see the peak voltage.
Thanks again
