RF link to transmit variable value
Hello,
I have two Basic Stamp Homework Boards (can get BOE if needed) and a 433 MHz transmitter and receiver.
I need to make a program that will read a pushbutton switch (1, 2, or 3) on the sending board, and use it to set the value of a variable on the receiving board.
The receiving board is controlling a servo. The three buttons will each toggle a different action from the servo.
I can make a program that runs the different actions based on the state of a variable, using simple if...then statements. I can also make the program that sets the variable value from the pushbutton on the transmitting board. But I'm having a bit of trouble deciphering the example programs for the Transmitter/Receiver and applying them to what I need.
Can anyone give me some help or advice? Thanks in advance.
For a quick "how-to" on RF communication, check out the Wireless Musical Keyboard Mini-Project. It shows you how to play different tones on a piezospeaker using 3 pushbuttons. You will definitely need to use the techniques Mike mentioned for your project, but this should help get you off and running.
Happy Developing!
Jessica
Jessica Uelmen
Education Department
The music program is very similar to what I want to do...instead of the freqout I can just sub in my pulsout statement.
