SX's programmable without SX-key?
So my question is... Is there a way to program the SX28AC/DP-G without an SX-Key. For instance, I've looked through the BS2-IC carrier board and found that it is very simple to program the IC through a db9 connector (or usb) with just a few connections. But i'm wondering how to program the SX, but the data sheet isn't much help.
······ I'll try everything once [noparse]:)[/noparse]
The SX is a single chip micro, and like all "flash" memory micros, generally requires a programming module of some kind to handle the high-speed data transmission and high voltages needed for "flashing" code into the chip. Programming module's often include some kind of debugging capability as well (SXs, PICs, etc, do not have "DEBUG" to the PC in quite the same way as the Stamp).
Is the price of the Key/Blitz the issue? You only need ONE --- then your only cost for projects is the chips (~$4) and optionally a resonator ($1-$2 depending on source).
I would suggest you look over the SX-Key Manual (it's the SX manual, really) and perhaps download the free SX IDE (coding application for your PC) and see what you think *before* spending any $$.
Typically I don't spend too much on my hobbies, but I like to live a little. The cost issue is simply because that drives the overall price to build my bot up. [noparse]:)[/noparse]
I have yet to build very many yet, with microcontrollers anyway, but I always try to make what components I already have used before buying anything to cut the costs. I actually purchased last night, after many tiring hours of research a PROP chip/plug/5MHz crystal/I2C 32KB EEPROM because I have always been interested in learning the PROPELLER line of microcontrollers as well. I will do a little more research on the SX before starting in to it at the moment.
I say that now, but most likely I will buy it too here in about a week [noparse]:)[/noparse]
Thanks for the info zoot!
being on a tight budget too, I wrestled with this also, but came to the same conclusion folks do early on in looking at the SX. The key is the way to go. Life's short, time is MORE valuable than money. (Building your own programmer for the SX would be very complex - this comes up in the forum often ... note the threads running here now. I've studied the timing diagrams - that alone shied me away from the attempt)
After banging my head for *hours* against bad code using a Blitz (which has no real debugging), I borrowed a friend's KEY - and spotted the problem in < 30 seconds. DOH!
Even if you use the ultra-cool Prop, I'd suggest you do indeed take a serious look at the SX. It is so flexible that it can do almost anything. Maybe your Prop-SX powered bot can make you (and your OtherHalf) coffee !
cheers (and my 2c)
- Howard in Florida
Buzz Whirr Click Repeat
