Propeller IO pin AC parametrics?
Parallax, What are the minimum/typical/maximum transition times for Propeller IO pins?
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
--Steve
Did the Propeller data sheet help at all?
www.parallax.com/Portals/0/Downloads/docs/prod/prop/PropellerDatasheet-v1.2.pdf
I can't find anything in the data sheet about pin transition times...
"VOOM"?!? Mate, this bird wouldn't "voom" if you put four million volts through it! 'E's bleedin' demised!
I thought that maybe something in there would be helpful.
Maybe you should try tech support then?
--Steve
