Safe clamping diode current
What is the recommended clamping diode current for each Propeller IO pin? Ideally, you wouldn't have any, but when interfacing higher voltage(>3.3V) devices, there will always be a little. I am interfacing the Propeller to a Mosfet Driver chip. I have a couple of 100k pull-up resistors, attached to 12V, at each input of the driver chip. The Propeller will be driving the inputs, but I need the pull-up resistors to ensure certain states in the driver chip when no propeller is attached.
So, if I have the pull-up resistors attached to 12V, and the clamping diodes in the propeller begin clamping at 3.6V, then that means each diode will be sinking 84uA. To me, this sounds fine. Is it?
