reality check on creating a millisecond resolution timer using ctra/ctrb — Parallax Forums
northcovenorthcove Posts: 49
edited 2009-05-18 17:57 in Propeller 1
Hi everybody,
I wish to create a millisecond-resolution timer that doesn't require its own cog (cogs are precious & finite resources!) Given the functionality of ctra/ctrb, this seems easy to do: accumulate phsa such that bit 31 toggles at 1kHz and then count those toggles using ctrb. Here's the code I have so far:
con
  strobe_pin = 11
pub ms_timer_test
  dira [noparse][[/noparse] strobe_pin ]~~        'set output for phsa[noparse][[/noparse]31]
  ctra [noparse][[/noparse] 30..26 ] := %00100     'output phsa[noparse][[/noparse]31]
  ctra [noparse][[/noparse] 5..0 ] := strobe_pin  'specify output pin
  frqa := $8000_0000 / ( clkfreq / 2_000 ) '1K Hz pos edge freq
  ctrb [noparse][[/noparse] 30..26 ]:= %01010      'count pos edges on pin
  ctrb [noparse][[/noparse] 5..0 ] := strobe_pin
  frqb := 1
  'at this point phsb will be counting (approximately) milliseconds
This code appears to do the job however I see several possible drawbacks:
- a pin is required for phsa[noparse][[/noparse]31] output
- accuracy is subject to crystal stability (probably okay for my application)
- there is a teensy error introduced because $80000000 cannot be evenly divided by clkfreq.
- the timer will roll over after 49.7 days.
- why don't any other timing classes in the obex use this technique...some impls create a cog that waitcnts to increment a counter.
Anybody have any recommendations?
Christopher
  • TimmooreTimmoore Posts: 1,031
    edited 2009-05-18 00:08
    I use this technique, though if I remember correctly it came from Phil and Rayman.
    You can remove the error from $80000000 by using a trick from Phil of using a frqa of 256 and then calculate ms by multiplying the phsb by $35AFE535
    Other issues is the time is only available in that COG since the counters are only available there. I use an existing cog that is polling a bunch of stuff (sensors), to query the counters and store the time in hub memory for other cogs - you lose accuracy depending on the polling period do this. It also calculates seconds, etc so it doesn't have the 49.7 day roll over problem.
  • northcovenorthcove Posts: 49
    edited 2009-05-18 00:34
    Tim, good points and exactly the feedback I was hoping to receive.
    Like yourself I'm polling a bunch of stuff in the caller cog. It can also periodically copy phsb into hub memory for other cogs to read.
    I can only hope that my project will run long enough between reboots that the rollover after 49.7 days will be an issue!
    edited 2009-05-18 01:25
    I have attached the timer object I use and the test code from when I first wrote it. I was right many of the ideas were·from Rayman and Phil.
    I added some extra stuff to correct for delays in updating counters across cogs - uses the diff of cnt value from the counter poll to the cnt when time is obtained to update the ms to higher accuracy.
    Thanks for that. Nice implementation. One recommendation: have Init take local timezone.
