Prop restarts after starting serial communication — Parallax Forums
propwellpropwell Posts: 87
edited 2009-05-19 06:53 in Propeller 1
Hi together,
i've got a Propeller-Program running, which uses the SerialMirror.spin (but the same problem appears with the FullDuplexSerial.spin).
When I start the serial comunication with "start(...)", after about half a second the propeller restarts completeley for about 3 or 4 times, and then the program runs completely perfect.
Is there any thing, that can make the Propeller restart, a conidition that affects the Serial Comunication?
Thank you,
propwell
    edited 2009-05-17 16:28
    Just a guess but the reset is controlled from the dtr line (pin4) Is the thing you are communnicating with using handshakes?? Try with "No flow control"
  • hover1hover1 Posts: 1,929
    edited 2009-05-17 16:53
    propwell said...
    Hi together,
    Thank you,
    propwell
    Are you running the program with the USB cable disconnected? If so, we just had a recent conversation on this at:
    http://forums.parallax.com/showthread.php?p=790298
    I'm running Simple_Serial.spin to talk to a serial LCD in a GPS application. The pullup on A30 worked for me.
    Jim
    Jim
    edited 2009-05-18 13:50
    Hello Popwell,
    usual PC-terminalsoftware toggles the DTR-PIN when opening the com-port
    PST.EXE from parallax does it NOT but ALL other that I have tested
    If you use a connection that does noz include the DTR-Line it won't reset.
    But you need the DTR-line for programming the Propeller
    ou could use some other two pins to drive a serial connection
    best regards
    Stefan
  • propwellpropwell Posts: 87
    edited 2009-05-18 13:58
    i'm sorry, but as i'm pretty new in the Microcontrollerbusinnes ( [noparse];)[/noparse] ) i don't really understand your answer:
    - what is the DTR-Pin on the Prop?
    - in my Program, i use Pins 30 an 31 for the serial comunication! is one of these the DTR-Pin?
    Thank you very much for your answers!
  • RaymanRayman Posts: 16,257
    edited 2009-05-18 15:44
    Sounds like that USB cable problem as hover1 mentions...
    edited 2009-05-18 15:56
    propwell,
    The PC's (or USB's) DTR pin is used by the Propeller Tool to reset the Prop to begin an upload sequence. Any time a connected PC toggles DTR, the Prop's /RST pin is pulled low momentarily, and the Prop resets. What StefanL38 points out is that most terminal programs, when they open a port, toggle the port's DTR line. Rayman and hover1 think that DTR is getting toggled by backfeeding power through the Prop Plug or onboard USB chip. Which of these is true depends on the answer to this question: When you observe this behavior, is your PC connected to the Prop, or not?
    edited 2009-05-18 20:48
    well actually i don't have the Propeller here at the moment, but i'm pretty sure that this problem only occured AFTER disconecting (and restarting) the Propeller...
    edited 2009-05-18 22:59
    In that case, add a 2.2K pullup to pin A30, and the problem should go away.
    edited 2009-05-18 23:56
    Phil Pilgrim (PhiPi) said...
    Yup, worked for me.
    @propwell
    If you want to understand the problem more, these are some of the·past posts on the problem:
    http://forums.parallax.com/showthread.php?p=651731
    And Phil diagnosised it pretty well.
    Let us know if that works for you.
    Jim
    On my home made demoboards I pull P30, P31 and the reset pin high with 4.7K or 10K resistors and have built in jumpers so that I can isolate restet, and-or reverse P30, P31.
