Propeller Tool v1.2.6 Released — Parallax Forums
Jeff MartinJeff Martin Posts: 762
edited 2009-05-21 23:28 in Propeller 1
A new release of the Propeller Tool (v1.2.6) is now available on the Parallax website:
http://www.parallax.com/tabid/442/Default.aspx
This version includes a few enhancements and bug fixes, but the main point of the release is everything that comes with it.· Here's a summary:
  • Propeller Help (ie: on-line help) that is significantly enhanced and includes updated information on the software and hardware, plus the Spin Language Tutorial, examples, etc.
  • The newly updated·Propeller Education Kit Labs-Fundamentals text and all it's example source are now included.
  • Updated Quick Reference pdf.
  • Updated Propeller Manual pdf (v1.1).
  • Updated Propeller Datasheet pdf.
  • New objects and updated to existing objects.
  • Parallax Serial Terminal (plus an object to go with it).
  • Updated USB driver.
  • Access to many of the above items is available from the Propeller Tool's help menu.
Check out this page to learn more details:
http://www.parallax.com/ProductInfo/Microcontrollers/PropellerGeneralInformation/PropellerDownloads/PropellerToolSoftware/tabid/609/Default.aspx
What's Next?
Many more·enhancements and fixes are in the works for·the Propeller Tool and the Propeller Help over the coming months!· Stay tuned to the forum and Twitter for the announcement sometime in the summer.
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
  • RaymanRayman Posts: 16,461
    edited 2009-05-16 00:15
    Thanks. I've been pretty happy with 1.2.5... I think all the major problems have been worked out already. Glad to see new updates though.
    edited 2009-05-16 00:22
    Wow. Bookmarks in the manual! I don't believe it. I see your taking some wind out of my sails... Still, I think I like my bookmarks better!
  • jazzedjazzed Posts: 11,803
    edited 2009-05-16 00:30
    Rayman, I've enjoyed your .pdf ... Kudo's for good leadership.
    --Steve
    Propalyzer: Propeller PC Logic Analyzer
    http://forums.parallax.com/showthread.php?p=788230
    edited 2009-05-16 00:49
    Nice bug reporter built in!
    @Ray: we'll always know who did it first. [noparse]:)[/noparse]
    OBC
    New to the Propeller?
  • hover1hover1 Posts: 1,929
    edited 2009-05-16 03:05
    Ray,
    OBC beat me to it. We know you did it first. But great minds do think alike!
    Jim
  • CapdiamontCapdiamont Posts: 218
    edited 2009-05-16 13:51
    So far, with 1.2.6 I'm able to run it in Vista without compatibility mode. With 1.2.5 I had to run it in XP SP2 compatibility mode.
    edited 2009-05-16 15:05
    Aka: CosmicBob
  • AleAle Posts: 2,363
    edited 2009-05-16 15:32
    I do not use PropTool anymore. It let me down. After 2 years of (no waiting because I use BST, on Mac OSX) it does not offer anything new. Look at what Brad or mpark for that matter got in much less time and not being paid for to do!, and multi-platform. I know nothing was promised but It did not even work well in the only platform it supported! :-(
    Sorry.
    Ale
    Visit the home of pPropQL, pPropQL020 and OMU for the pPropQL/020 at omnibus.uni-freiburg.de/~rp92
    edited 2009-05-16 16:35
    Thanks Jeff. The information updates are appreciated!
    Man, you Parallax guys are getting downright HIP! Twitter, web-meetings (I can't stand the word webinar), snazzy news letter, U-Tube... Nice.
    (This might give me a reason to use Twitter)
    Just got done checking out the updated PDF. Excellent!! Thanks a bunch. This reference is very significantly improved in both clarity and usability. When programming in assembly language, I had setup a list of instructions where I could just go click on them to pick up some info. The book marks, truth tables, and our friend the octothorpe gets proper treatment in this edition! (literals)
    Very nicely done, and right when I've a week off to play too! Double sweet!
    Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
    Safety Tip: Life is as good as YOU think it is!
    Post Edited (potatohead) : 5/16/2009 4:58:47 PM GMT
  • Jeff MartinJeff Martin Posts: 762
    edited 2009-05-20 11:49
    To all:· You're welcome!
    To Rayman:
    Rayman said...
    Not intentional, of course.· Just trying to improve it as we go.·Your excellent example of what could have been done in the pdf was a big help! [noparse]:)[/noparse]
    --Jeff Martin
    · Parallax, Inc.
    Post Edited (Jeff Martin (Parallax)) : 5/20/2009 11:54:28 AM GMT
  • lonesocklonesock Posts: 917
    edited 2009-05-20 19:30
    Thanks! I really like the new documentation!
    If I could mention 2 things I noticed:
    - In the quick reference assembly section, it would be nice if REV was documented as reversing the lower *32-N* bits, as that is different from the SPIN version (which reverses the lower N bits, as you would expect), and it's caught me at least twice [noparse][[/noparse]8^)
    - I really like that in the manual there is now example code for multiplication and division and square root. For the square root, it might be nice to use the (much faster) version that chip came up with and posted in the forums a while back, on the off chance that someone wants to use that code verbatim in their projects. The post is quoted below:
    Chip Gracey said...
    Here's the smaller version (now 'mask' is a register containing $40000000 which gets used directly and rotated all the way back to its original value):
            mov     root,#0         'reset root
     :loop  or      root,mask       'set trial bit
            cmpsub  input,root  wc  'subtract root from input if fits
            sumnc   root,mask       'cancel trial bit, set root bit if fit
            shr     root,#1         'shift root down
            ror     mask,#2     wc  'shift mask down (wraps on last iteration)
     if_nc  jmp     #:loop          'loop until mask restored
    lonesock
    Piranha are people too.
  • RichKRichK Posts: 54
    edited 2009-05-20 20:51
    Looks great.
    Just one problem I seem to be having. If I select "PE Kit - Examples" in the folder drop down, it goes to the folder under PropTool1.2.6\Examples\PE Kit but only shows one file, the PDF. If I go to "Show All Folder" there are all the code folders there along with all the other folders in the world. How do I get the code folders to show up when I just go to the Examples? The "PE Kit" folder doesn't show it has any subfolders (no + to click).
    Thanks.
    Rich.
  • phil kennyphil kenny Posts: 233
    edited 2009-05-21 05:11
    If you click on the small button as shown in the attached image
    you will be able to see the subfolders under the Example folder.
    650 x 305 - 126K
    edited 2009-05-21 13:21
    Thanks Phil, that's the "Show All Folders" button. But how do they get to the point of showing the "Examples" and "PE Kit" folders. If I do that under show all, go to one of those subdirectories and open a file, that dir will then show up when "Show All" is off. If I go to the dir under show all and do not open a file, disable show all, that dir is gone again. Oh well, that's all that seems to annoy me, I can live with it.
    edited 2009-05-21 16:26
    lonesock said...
    Hi lonesock,
    Thanks, I'm glad to hear that.· You made a good point.· I'll make that update.
    lonesock said...
    Funny, I was unaware of this variation.· Thanks!· I'll include that as well.
    To RichK and phil kenny,
    Thanks for your input; this is one of the things that will be enhanced soon since the current version doesn't treat it as well as it could.· Currently, the list of folders that appear are those of the last 10 files opened.· The enhancements will include all the installed example folders (by default) as well as any favorite folders the user specifies.
    --Jeff Martin
    · Parallax, Inc.
  • SSteveSSteve Posts: 808
    edited 2009-05-21 22:21
    Jeff Martin (Parallax) said...
    This version includes a few enhancements and bug fixes, but the main point of the release is everything that comes with it. Here's a summary:
    ...Updated Quick Reference pdf...
    Jeff:
    Is the Quick Reference available outside the Propeller Tool exe? I don't see it on the Propeller Downloads page. Your non-Windows customers can't get at it in an exe.
    Thanks!
    OS-X: because making Unix user-friendly was easier than debugging Windows
    links:
    My band's website
    Our album on the iTunes Music Store
  • SRLMSRLM Posts: 5,045
    edited 2009-05-21 23:21
    @SSteve
    A short term solution: I've attached it.
    Thanks!
    links:
    My band's website
