IR transciever home made
··· Getting ready to fire up my first boe bot and realised the IR setup in the book wouldn't fly on my robot. Oh well back to basement engineering. I used 1/4 of a radio shack 2.25" x 2.25" proto board and a few header pins. I made the cables from cables salvaged from old computer main frames. I went all out and soldered and labled pind to the boe bot end making easy to plug directly into the boe I/O header saving breadboard space. I always perfered plug and play. It is good to always have a few long break away headers laying around. Hope this will be usefull to someone. Intermediate soldering skills, an IC type soldering iron, and IC type solder may be usefull. Attached are some pics to help.
The more you learn, the more you find you don't know. It is neverending. Confucous 550BC
Great work!
······ I'll try everything once [noparse]:)[/noparse]
The more you learn the more you find you don't know. It is neverending.
Jax
If a robot has a screw then it must be romoved and hacked into..
