Controlling relays with prop
Hi there,
1. How can I turn on a relay (5V coil voltage) with Prop signal (3.3V only)?
2. How many maximum relays I can control individually with one prop (are there any·AMP restrictions from prop)?
Thanks in advance.
Sincerely,
Venkata.
Thanks in advance.
Sincerely,
Venkata.
the only limit to the number is the 50mA max load on each pin.
My new unsecure propmod both 1x1 and full size arriving soon.
Refer to the Propeller Datasheet, page 25 for the current restrictions for the Propeller. The max. current for each pin is 40mA and the max. total current for the whole Propeller is 300mA.
Just because it says 5V on the package doesn't mean that you can't use your prop to drive it directly... it is worth a try.
My favorite relay is a 5V RadioShack reed relay. At one time, I use them for almost everything. Your prop has enough umph in it so that you can put a diode in and the relay will still work.
