Torpedo LifeGuard
I have been researching torpedoes and submersibles recently for a school project. I am also a fan of the television show "Deadliest Catch," which depicts crab fisherman on the Bering Sea. It seems every year that at least one ship sinks. This got me thinking: What if you had a torpedo that shot out to the sinking boat carrying lifesaving equipment. This would be a temporary lifesaving device until the Coast Guard could mobilize and reach the fishermen. The ship could also be used for capsizing boats elsewhere.
A few weeks ago, I began researching propulsion technology for this. I need help with a few problems that I can not seem to find the answers to:
-Would the GPS system work underwater? (10-50ft)
-Would it be possible to transmit a GPS signal at least 10-20 miles?
That is it for the time being. I may have some questions in the future about smaller issues. Thank you in advance for your answers.
GPS does not work underwater; but a tethered, floating antenna might work, if it didn't create too much drag. GPS signals are transmitted directly by satellite, so there's no need for a repeater — even out at sea.
I'm sorry, was that sarcasm? I couldn't tell.
Doubt it, if it's like any other RF system, but you can just try it out yourself. Sometimes, the best way to figure things out is to just experiment on your own.
"Would it be possible to transmit a GPS signal at least 10-20 miles?"
You should as long as you have a satellite in view. If you meant RF, there are walkie-talkies capable of transmitting upwards of 25 miles. Not underwater, though. Just the expensive ones they use for submarines can. You might be able to extend the antenna above the torpedo, though, so it can transmit by air.
Edit: Wow people post fast. Maybe I should·think faster. Oh well, at least you got to here some of the some stuff from 2 people : )
PG
PG
Pre-Sinking-Salvage! A new industry! Charge the captains for the loss before they lose it!
As for the transmitters, assuming that you don't mean on the GPS frequencies, then there are lots of options. Specifically, the 400 and 900 MHz areas are unlicensed and you can buy modules (Digi Xtends might work, I've never tried them but they're rated for 40 mi LOS).
http://www.landfallnavigation.com/epirb.html
Most are also equipped with at least one life raft that inflates when it's deployed over the side and all crew members must have, and know how to use, survival/emersion suits. The problem is that the crew doesn't always have the time to put on their survival suits and get the raft(s) in the water before the ship goes down or capsizes. That's why they call it the deadliest job.
Duffer
Post Edited (Duffer) : 5/14/2009 3:01:53 PM GMT
Another use for the device is that it might be able to pull a small boat to the shore if it breaks down in a river. However, strong motors might be needed for that.
I agree that a sane, sober, alert and well rested captain and crew would prevent many more deaths than ANY safty device.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
Probably beyond your abilities but torpedo have now been developed to travel at supersonic speeds. mach 10 is possible by enveloping the torpedo in a small pocket of air.
My new unsecure propmod both 1x1 and full size arriving soon.
Post Edited (mctrivia) : 5/15/2009 5:35:45 AM GMT
However, I don't know whether the person should be able to get on. Propelling a boat with people on it would be much harder than propelling one with people in life jackets hooked up to tow lines.
Searider
The part that worries me is navigation. Originally, I had envisioned using a GPS unit to navigate to the sinking ship, and using some sort of pre-made digital map that would be used to make a path that avoided land. However, I probably still need sensors that could detect stumps, weeds, and other obstacles. I have searched and haven't found anything that is within my budget for a prototype.
They do give indication of mass of object, and would also tell you how far off bearing the mass is located, by using sensors on attached to the screen.
Here is a quick sketch of the basic torpedo so far. I'll post some detailed CAD files soon.
Post Edited (Nu World Network) : 5/16/2009 7:35:37 PM GMT
Searider
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
I would make the hatch self ejecting though so people do not have to get to the boat to release it. 2 simple ejection systems is a spring loaded cover held in place by electromagnets, solinoids, or exploding bults. down side is cover is 1 time use only as you will not likely find afterwards and it may hit someone. another option is having a large linear actuator that pulls the cover inside the boat.
