PASM variables using RES
JonnyMac
If I define a PASM variable with RES is it safe to assume that on launching the cog that variable will be zero, or could it be some random number based on stray bits in the cog ram?
Composite NTSC sprite driver: http://forums.parallax.com/showthread.php?p=800114
NTSC color bars (template): http://forums.parallax.com/showthread.php?p=803904
