Possibly Fried Infrared Reciever?
I recently purchased an infrared receiver (http://www.parallax.com/Store/Sensors/ColorLight/tabid/175/CategoryID/50/List/0/Level/a/ProductID/177/Default.aspx?SortField=ProductName,ProductName) for a project.While wiring it up, I misunderstood the diagram and didn't wire it properly, so it was not working. When I asked a friend for help, he reversed it, causing it to become incredibly hot. I now have figured out the error in the wiring, but the circuit is not working. I don't know if I am still using an infrared remote wrong, the circuit is fried, or I just fried a pin on the board.
The connection is supposed to be set up so board VDD connects to 1, board ground connects to 2, and pin 9 connects to 3. Initially, I wired it with VDD connected to 1, but pin 9 to 2 and ground to 3. When my friend reversed it, we had VDD to 3, pin 9 to 2, and ground to 1.
Also, for anyone who has worked with this circuit before, what code should I program a universal remote with? I have a Sony Universal remote and I'm uncertain which of the 3 codes is best to use.
You have my sympathy.
And sadly, the radioshack near me doesn't sell them. I don't exactly understand why, considering it sells a few of the less commonly used sensors (to my knowledge), but it doesn't stock those. If it did, I wouldn't have tried to do an engineering final project at 11 PM at night before it was due since I had to wait for an IR sensor to be delivered.
Luckily, like you, it still seems to function fine.
Perhaps it needed to cool down before it worked again?
As I'm learning, don't depend on anything that might have been damaged by reversed power supply. It might work now, it might work for years, but it just as possibly
might konk out in the next five minutes with absolutely no warning.
