Propeller Simulation in Verilog — Parallax Forums
jazzedjazzed Posts: 11,803
edited 2009-11-06 01:49 in Propeller 1
Hi.
Thought I would reveal one of my Propeller projects. Verilog is a Hardware Description Language (HDL) for creating integrated circuits. I have created a single hub/cog module for simulations with Icarus Verilog. The model is not "cycle accurate" at this point (but will be) and is NOT intended for creating an image for use in an FPGA. The model does not borrow from anyone's previous work. Most of the PASM instructions have been added and many are verified to be working as expected.
What you see below is a dump of a COG simulation from a Propeller Verilog model. This is useful for connecting to other Verilog modules to verify ideas such as the Synchronous CPLD idea discussed in the 6.6MB/s thread. The dump specifically addresses the Asynchronous memory read model with data on P0..7 and address on P8..P31.
I've been working on running Chip's booter.spin code, but I've hit a wall there ... having trouble making Verilog share a pin on the EEPROM SDA line. For now I'll just give that a rest so I can focus on other things.
Using the Programming Language Interface (PLI), a model can read Propeller assembly and run the code on the COG simulation. In the future, I expect to add interfaces to "time-tick and pin data" files for describing inputs to the model so that one or more forms of a binary image can be shared ... and so that I don't have to give away my source code [noparse]:)[/noparse]. Once the full instruction set is verified, I may offer binary variations of this work on a "specified test bench."
C:\iVerilog\projects\propeller>test loadxmm
C:\iVerilog\projects\propeller>del loadxmm.binary
C:\iVerilog\projects\propeller>cat loadxmm.spin
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
PUB main
  cognew(@initxmm,0)
DAT
initxmm        ' initialize
               mov      dira,   mask
               mov      addr,   par
               call     #loadxmm8
               call     #loadxmm16
               call     #loadxmm32
               ' debug stuff
finish         or       dira,   #$ff
               mov      outa,   val
               ' kill cog
               cogid    cog
               cogstop  cog
loadxmm32      ' 16 total instructions for 3.3V < 50ns SRAM. Direct address/data bus
               mov      outa,   addr
               shl      outa,   #8
               add      outa,   _0x300  'add to address to fix endian order
               nop
               mov      val,    ina     'xxxxxxxxxxxxxxxxxxxxxxxxAAAAAAAA .
               sub      outa,   #$100
               ror      val,    #17 wc  'xxxxxxxxxAAAAAAAAxxxxxxxxxxxxxxx A0
               movi     val,    ina     'bBBBBBBBBAAAAAAAAxxxxxxxxxxxxxxx A0
               sub      outa,   #$100
               shr      val,    #8      '........bBBBBBBBBAAAAAAAAxxxxxxx A0
               movi     val,    ina     'cCCCCCCCCBBBBBBBBAAAAAAAAxxxxxxx A0
               sub      outa,   #$100
               shr      val,    #8      '........cCCCCCCCCBBBBBBBBAAAAAAA A0
               movi     val,    ina     'dDDDDDDDDCCCCCCCCBBBBBBBBAAAAAAA A0
               rcl      val,    #1      'DDDDDDDDCCCCCCCCBBBBBBBBAAAAAAAA A0
loadxmm32_ret  ret
loadxmm16      ' 10 total instructions for 3.3V < 50ns SRAM. Direct address/data bus
               mov      outa,   addr
               shl      outa,   #8
               add      outa,   #$100  'add to address to fix endian order
               nop
               sub      outa,   #$100
               ror      val,    #17     'xxxxxxxxxAAAAAAAAxxxxxxxxxxxxxxx A0
               shr      val,    #15
loadxmm16_ret  ret
loadxmm8      '  5 total instructions for 3.3V < 50ns SRAM. Direct address/data bus
               mov      outa,   addr
               shl      outa,   #8
               nop
loadxmm8_ret   ret
cog            long 0
_0x300         long $300
addr           long $0
mask           long $ffffff00
val            res 1
C:\iVerilog\projects\propeller>.\propellent /compile /savebinary loadxmm.spin
C:\iVerilog\projects\propeller>.\spin2pasm loadxmm.binary  1>loadxmm.txt
C:\iVerilog\projects\propeller>del tb_loadxmm
C:\iVerilog\projects\propeller>iverilog -o tb_loadxmm tb_loadxmm.v
C:\iVerilog\projects\propeller>vvp -v tb_loadxmm
Compiling VVP ...
Compile cleanup...
 ... Linking
 ... Removing symbol tables
 ...     2230 functors
                160 table
                  0 bufif
                 32 resolv
                980 variable
 ...    10338 opcodes (180224 bytes)
 ...      148 nets
 ...        9 memories
 ...        4 scopes
Running ...
VCD info: dumpfile propeller.vcd opened for output.
$readmemh(loadxmm.txt): Not enough words in the read file for requested range.
COG  0 un-reset         43  520
COG download  0 complete. PC 000 INST a0bfec2b
COG  0 PASM[noparse][[/noparse]000] = a0bfec2b i 28 zcri 0010 MOV      c f d 1f6 ffffff00 <- 00000000 s  02b ffffff00 DIRA     C 0 Z 0 ioa 11111111111111111111111101010101 cnt 0000016c
COG  0 PASM[noparse][[/noparse]001] = a0bc55f0 i 28 zcri 0010 MOV      c f d 02a 00000040 <- 00000000 s  1f0 00000040     PAR  C 0 Z 0 ioa 00000000000000000000000001010101 cnt 00000170
COG  0 PASM[noparse][[/noparse]002] = 5cfc4e23 i 17 zcri 0011 JMP      c f d 027 5c7c0003 <- 5c7c0000 s #023 a0bfe82a          C 0 Z 0 ioa 00000000000000000000000001010101 cnt 00000174
COG  0 PASM[noparse][[/noparse]023] = a0bfe82a i 28 zcri 0010 MOV      c f d 1f4 00000040 <- 00000000 s  02a 00000040 OUTA     C 0 Z 0 ioa 00000000000000000000000010101010 cnt 00000178
COG  0 PASM[noparse][[/noparse]024] = 2cffe808 i 0b zcri 0011 SHL      c f d 1f4 00004000 <- 00000040 s #008 0c7c5003 OUTA     C 0 Z 0 ioa 00000000000000000000000010101010 cnt 0000017c
COG  0 PASM[noparse][[/noparse]025] = 00000000 i 00 zcri 0000 NOP      c 0 d 000 a0bfec2b <- a0bfec2b s  000 a0bfec2b          C 0 Z 0 ioa 00000000000000000100000010101010 cnt 00000180
COG  0 PASM[noparse][[/noparse]026] = a0bc59f2 i 28 zcri 0010 MOV      c f d 02c ffffff55 <- xxxxxxxx s  1f2 ffffff55     INA  C 0 Z 0 ioa 00000000000000000100000001010101 cnt 00000184
COG  0 PASM[noparse][[/noparse]027] = 5c7c0003 i 17 zcri 0001 JMP      c f d 000 a0bfec2b <- a0bfec2b s #003 5cfc4419          C 0 Z 0 ioa 00000000000000000100000001010101 cnt 00000188
COG  0 PASM[noparse][[/noparse]003] = 5cfc4419 i 17 zcri 0011 JMP      c f d 022 5c7c0004 <- 5c7c0000 s #019 a0bfe82a          C 0 Z 0 ioa 00000000000000000100000001010101 cnt 0000018c
COG  0 PASM[noparse][[/noparse]019] = a0bfe82a i 28 zcri 0010 MOV      c f d 1f4 00000040 <- 00004000 s  02a 00000040 OUTA     C 0 Z 0 ioa 00000000000000000100000010101010 cnt 00000190
COG  0 PASM[noparse][[/noparse]01a] = 2cffe808 i 0b zcri 0011 SHL      c f d 1f4 00004000 <- 00000040 s #008 0c7c5003 OUTA     C 0 Z 0 ioa 00000000000000000000000010101010 cnt 00000194
COG  0 PASM[noparse][[/noparse]01b] = 80ffe900 i 20 zcri 0011 ADD      c f d 1f4 00004100 <- 00004000 s #100 xxxxxxxx OUTA     C 0 Z 0 ioa 00000000000000000100000010101010 cnt 00000198
COG  0 PASM[noparse][[/noparse]01c] = 00000000 i 00 zcri 0000 NOP      c 0 d 000 a0bfec2b <- a0bfec2b s  000 a0bfec2b          C 0 Z 0 ioa 00000000000000000100000101010101 cnt 0000019c
COG  0 PASM[noparse][[/noparse]01d] = a0bc59f2 i 28 zcri 0010 MOV      c f d 02c ffffff55 <- ffffff55 s  1f2 ffffff55     INA  C 0 Z 0 ioa 00000000000000000100000101010101 cnt 000001a0
COG  0 PASM[noparse][[/noparse]01e] = 84ffe900 i 21 zcri 0011 SUB      c f d 1f4 00004000 <- 00004100 s #100 xxxxxxxx OUTA     C 0 Z 0 ioa 00000000000000000100000101010101 cnt 000001a4
COG  0 PASM[noparse][[/noparse]01f] = 20fc5811 i 08 zcri 0011 ROR      c f d 02c ffaaffff <- ffffff55 s #011 84ffe900          C 0 Z 0 ioa 00000000000000000100000010101010 cnt 000001a8
COG  0 PASM[noparse][[/noparse]020] = 58bc59f2 i 16 zcri 0010 MOVI     c f d 02c 552affff <- ffaaffff s  1f2 000000aa     INA  C 0 Z 0 ioa 00000000000000000100000010101010 cnt 000001ac
COG  0 PASM[noparse][[/noparse]021] = 28fc580f i 0a zcri 0011 SHR      c f d 02c 0000aa55 <- 552affff s #00f 21fc5811          C 0 Z 0 ioa 00000000000000000100000010101010 cnt 000001b0
COG  0 PASM[noparse][[/noparse]022] = 5c7c0004 i 17 zcri 0001 JMP      c f d 000 a0bfec2b <- a0bfec2b s #004 5cfc3009          C 0 Z 0 ioa 00000000000000000100000001010101 cnt 000001b4
COG  0 PASM[noparse][[/noparse]004] = 5cfc3009 i 17 zcri 0011 JMP      c f d 018 5c7c0005 <- 5c7c0000 s #009 a0bfe82a          C 0 Z 0 ioa 00000000000000000100000001010101 cnt 000001b8
COG  0 PASM[noparse][[/noparse]009] = a0bfe82a i 28 zcri 0010 MOV      c f d 1f4 00000040 <- 00004000 s  02a 00000040 OUTA     C 0 Z 0 ioa 00000000000000000100000001010101 cnt 000001bc
COG  0 PASM[noparse][[/noparse]00a] = 2cffe808 i 0b zcri 0011 SHL      c f d 1f4 00004000 <- 00000040 s #008 0c7c5003 OUTA     C 0 Z 0 ioa 00000000000000000000000010101010 cnt 000001c0
COG  0 PASM[noparse][[/noparse]00b] = 80bfe829 i 20 zcri 0010 ADD      c f d 1f4 00004300 <- 00004000 s  029 00000300 OUTA     C 0 Z 0 ioa 00000000000000000100000010101010 cnt 000001c4
COG  0 PASM[noparse][[/noparse]00c] = 00000000 i 00 zcri 0000 NOP      c 0 d 000 a0bfec2b <- a0bfec2b s  000 a0bfec2b          C 0 Z 0 ioa 00000000000000000100001110101010 cnt 000001c8
COG  0 PASM[noparse][[/noparse]00d] = a0bc59f2 i 28 zcri 0010 MOV      c f d 02c ffffff55 <- 0000aa55 s  1f2 ffffff55     INA  C 0 Z 0 ioa 00000000000000000100001101010101 cnt 000001cc
COG  0 PASM[noparse][[/noparse]00e] = 84ffe900 i 21 zcri 0011 SUB      c f d 1f4 00004200 <- 00004300 s #100 xxxxxxxx OUTA     C 0 Z 0 ioa 00000000000000000100001101010101 cnt 000001d0
COG  0 PASM[noparse][[/noparse]00f] = 21fc5811 i 08 zcri 0111 ROR      c f d 02c ffaaffff <- ffffff55 s #011 84ffe900          C 1 Z 0 ioa 00000000000000000100001001010101 cnt 000001d4
COG  0 PASM[noparse][[/noparse]010] = 58bc59f2 i 16 zcri 0010 MOVI     c f d 02c 552affff <- ffaaffff s  1f2 000000aa     INA  C 1 Z 0 ioa 00000000000000000100001010101010 cnt 000001d8
COG  0 PASM[noparse][[/noparse]011] = 84ffe900 i 21 zcri 0011 SUB      c f d 1f4 00004100 <- 00004200 s #100 xxxxxxxx OUTA     C 1 Z 0 ioa 00000000000000000100001010101010 cnt 000001dc
COG  0 PASM[noparse][[/noparse]012] = 28fc5808 i 0a zcri 0011 SHR      c f d 02c 00552aff <- 552affff s #008 0c7c5003          C 1 Z 0 ioa 00000000000000000100000110101010 cnt 000001e0
COG  0 PASM[noparse][[/noparse]013] = 58bc59f2 i 16 zcri 0010 MOVI     c f d 02c aad52aff <- 00552aff s  1f2 ffffff55     INA  C 1 Z 0 ioa 00000000000000000100000101010101 cnt 000001e4
COG  0 PASM[noparse][[/noparse]014] = 84ffe900 i 21 zcri 0011 SUB      c f d 1f4 00004000 <- 00004100 s #100 xxxxxxxx OUTA     C 1 Z 0 ioa 00000000000000000100000101010101 cnt 000001e8
COG  0 PASM[noparse][[/noparse]015] = 28fc5808 i 0a zcri 0011 SHR      c f d 02c 00aad52a <- aad52aff s #008 0c7c5003          C 1 Z 0 ioa 00000000000000000100000001010101 cnt 000001ec
COG  0 PASM[noparse][[/noparse]016] = 58bc59f2 i 16 zcri 0010 MOVI     c f d 02c 552ad52a <- 00aad52a s  1f2 000000aa     INA  C 1 Z 0 ioa 00000000000000000100000010101010 cnt 000001f0
COG  0 PASM[noparse][[/noparse]017] = 34fc5801 i 0d zcri 0011 RCL      c f d 02c aa55aa55 <- 552ad52a s #001 a0bc55f0          C 1 Z 0 ioa 00000000000000000100000010101010 cnt 000001f4
COG  0 PASM[noparse][[/noparse]018] = 5c7c0005 i 17 zcri 0001 JMP      c f d 000 a0bfec2b <- a0bfec2b s #005 68ffecff          C 1 Z 0 ioa 00000000000000000100000010101010 cnt 000001f8
COG  0 PASM[noparse][[/noparse]005] = 68ffecff i 1a zcri 0011 OR       c f d 1f6 ffffffff <- ffffff00 s #0ff xxxxxxxx DIRA     C 1 Z 0 ioa 00000000000000000100000001010101 cnt 000001fc
COG  0 PASM[noparse][[/noparse]006] = a0bfe82c i 28 zcri 0010 MOV      c f d 1f4 aa55aa55 <- 00004000 s  02c aa55aa55 OUTA     C 1 Z 0 ioa 00000000000000000100000000000000 cnt 00000200
COG  0 PASM[noparse][[/noparse]007] = 0cfc5001 i 03 zcri 0011 HUBOP    c f d 028 00000000 <- 00000000 s #001 a0bc55f0          C 1 Z 0 ioa 10101010010101011010101001010101 cnt 00000204
COG  0 PASM[noparse][[/noparse]008] = 0c7c5003 i 03 zcri 0001 HUBOP    c f d 028 00000000 <- 00000000 s #003 5cfc4419          C 1 Z 0 ioa 10101010010101011010101001010101 cnt 00000208
Event counts: (event pool = 1364)
       20290 thread schedule events
        9833 propagation events
       29326 assign events
      440384 other events
"Use: gtkwave propeller.vcd"
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
  • RaymanRayman Posts: 16,460
    edited 2009-05-13 00:41
    Sounds like fun! I was about to dive into FPGA stuff before I stumbled across the Propeller... It'd be nice to make custom Props though. Can you make one with 64 I/O pins?
  • jazzedjazzed Posts: 11,803
    edited 2009-05-13 01:09
    Rayman.
    I can make simulations with 64 I/O and MUL instructions too. But like I said sort of, my plan is to "make simulations, not chips."
    --Steve
    edited 2009-05-13 01:12
    I think the FPGA would have trouble with things like the counters and PLL's. And aren't most FPGA's a lot more expensive than the prop now?
    edited 2009-05-13 01:52
    I know that PLL's have been done on VirtexII. I have not implemented counters or WAITVID. That will be a PITA; possible but a PITA.
    No way that a 32 I/O FPGA Propeller could compete price-wise with P8X32A.
    --Steve
    edited 2009-05-13 03:35
    I really like the idea of being able to simulate the hardware as that would be the basis of a good debugger as you have no doubt found.
    As you and some others know,·I was playing with a cog emulation in an FPGA using Verilog.·I am not the only one. I am (was, because I stopped at Xmas to design some prop hardware) using a Xilinx Spartan-3A (XC3S400A).
    Just some info: The FPGA's will use a lot more power and cost more than a real prop.· While it may be possible to fit a prop in·my FPGA, the hub memory will definately not fit inside. There are much larger versions but they are all BGA with 400+ pins and $$$.
    · Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
    · Search the Propeller forums (via Google)
    edited 2009-11-04 18:37
    I'm reviving this project. The goal has changed:
      Create a functional FPGA with external HUB RAM that will be finished before Propeller II.
      A Propeller PASM compatible P8X32A/B FPGA core using 32MB external HUB RAM directly accessible to COGs
      in the natural way (directly accessible to LMM via special instructions) and running on Spartan 3E.
      I will abandon the effort only when Propeller II is ready for sale, when my FPGA board functions perfectly
      IMHO, I receive a "cease and desist letter" or post from Parallax, or stop for significant personal reasons.
      The target hardware will initially be the Diligent Spartan 3E S3E1600 FPGA Board. ... This board has 32MB
      Micron DDR 5ns memory, 16MB Intel StrataFlash Flash, Xilinx Program Flash, 16MB Serial Flash, DB15HD VGA
      PS/2 keyboard, 2 DB9 RS-232 connectors, RJ-45 Ethernet, 16-pin header for optional LCD modules, I/O
      connectors, and USB for programing.
      The Diligent 1600K board/PS is about $230, 500K board/PS is about $150 (international distribution available).
      It is unclear how many COGs could be put into the 1600K device with on-board FPGA COG RAM and external
      HUB RAM, but more than 8 is likely. One of my design goals is to allow any number of COGs (8 more or
      less) that will fit into a given device. It is unclear if 8 COGs will fit into the Spartan 3E-500K.
      I am committed to this since I'm sick of waiting for Propeller II, but I do not recommend anyone without sufficient
      knowledge in purchasing hardware until there is reasonable progress. Others who feel qualified are welcome to
      join me in development.
    • AleAle Posts: 2,363
      edited 2009-11-04 18:52
      jazzed, I'd like to know how much logic is needed for at least 1 COG. I know that 1.6M gates is quite a bit but do you have any estimation ?
      I'd love to join the development but I am just beginning with Verilog, I'm still thinking about gates and FFs instead of behaviour :-(. I just today got the CPLD code for memory control working with incrementing pointer. I have now to add a second pointer and well, it is sort of ready. Sorry for hijiking your thread.
      Great stuff !!
      Visit some of my articles at Propeller Wiki:
      MATH on the propeller propeller.wikispaces.com/MATH
      pPropQL: propeller.wikispaces.com/pPropQL
      pPropQL020: propeller.wikispaces.com/pPropQL020
      OMU for the pPropQL/020 propeller.wikispaces.com/OMU
      edited 2009-11-04 20:35
      I have done the instruction decoding, cog memory fetching and writing using dual access, flag testing and setting. I abandoned at the point of implementing the barrel shifter. I was working on a 1-4 cycle instruction with 2 pipes to give 1-3 cycles effective.
      Not sure if I am willing to disclose the code - would probably talk to Parallax first. It is in verilog for a Spartan 3A 200 $50 Avnet pcb.
      · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
      · Search the Propeller forums·(uses advanced Google search)
      edited 2009-11-04 21:49
      @Ale, I don't know yet how big one COG will be. I'm working with the verilog from my
      simulation model now to make it synthesizable ... could be a while before that's ready.
      As I said in so many words in another thread:
      I believe it's better to start too big than to start too small.
      @Cluso99, I've already stated my intentions.
      If Parallax wants me to stop I will, but I am quite sick of waiting for Propeller II.
      It's either this or abandon Propeller completely for me.
      I'm sure some folks here would like to see me abandon it and this forum [noparse]:)[/noparse]
    • nutsonnutson Posts: 242
      edited 2009-11-04 22:14
      You are a brave man. Jazzed. I got my Verilog soft-COG about half way, stable executing a substantial subset of ASM instructions at 150MHz/50MIPS. I got stuck at interfacing this CPU to the DE-1 board 256K16 memory, doubling as a 1024X512X8 bit XGA graphics memory (65MHz pixel frequency).· This required a serious asynchronous bus design with wait states and the lot, more than I could handle (see the simple CPU interface definition I started with).· With the board you have chosen I would go for a synchronous design with 4 COGS and 64KByte of hub memory, you have exectly 72KByte on chip fast dual port memory. Using·the 16 bit DDR DRAM·as hub·memory seems·a timing PITA to me.··
      Regards
      http://forums.parallax.com/showthread.php?p=762775
      768 x 576 - 85K
    • Ron SutcliffeRon Sutcliffe Posts: 420
      edited 2009-11-05 00:37
      @jazzed
      Well, I can certainly understand your frustration.
      Trying to do anything with C on Propeller, other than a perhaps a few party tricks, is like trying to lubricate a bicycle at a Well Head in Texas.
      The only reason C developer would choose Prop is take advantage of the video services availble in each cog.
      For what its worth, I think it would be better to develop standalone hardware optimized around large memory, but supporting access to Props Video and the PPL services. In other words leave the Video generator stuff off the hardware (AKA Prop1 with 64 pins·less Video and·PLL)
      I don’t image you are alone doing what you are doing, so there would be little point in Parallax asking you to stop, but may you will have to consider continuing a thread like this at another venue. If you do let me know [noparse]:)[/noparse]
      I can’t believe anyone would want to see you leave Prop land, your contributions would be surely missed.
      Ron
      Post Edited (Ron Sutcliffe) : 11/5/2009 6:44:33 AM GMT
      edited 2009-11-05 03:46
      Jazzed: I don't think anyone would like to see you leave the prop.
      I understand you want the Prop II. So do we all, but we are using what is available.
      From the work I did, I think you will find the counters the most complex part of the design. However, I guess you can put just the blocks in the FPGA for 1 VGA, 2 UARTs, etc as they are all available as free IPs.
    • Nick MuellerNick Mueller Posts: 815
      edited 2009-11-05 06:20
      WOW! You are nuts!
      The only contribution I can make is to wish you the very best for this project.
      Imagine what this means: A Prop in an FPGA, you could add clue-logic inside of the "Prop" and thus reduce size. Maybe even use some spare instructions for special purposes, add hardware I2C & SPI, have "unlimited" RAM, maybe even map regions of external RAM into HUB-RAM, maybe have more COGs, ...
      The possibilities seem to be endless!
      Chapeau!
      Nick
      Never use force, just go for a bigger hammer!
      The DIY Digital-Readout for mills, lathes etc.:
      YADRO
    • FredBlaisFredBlais Posts: 395
      edited 2009-11-05 16:32
      If I understand... we could run binary of Spin/asm source code generated from the prop tool in a soft-prop and have the choice of how many cogs or RAM we want? Maybe you'll want to look at recents·CoWare tools and LISA.
      LISA is...
      a Language targeting the description of Instruction Set Architecture. The aim is to capture all the information required to generate software tools (compiler, assembler, Instruction Set Simulator, ...) and implementation hardware (in VHDL or Verilog) of a given processor core.
      At the lab I'm working, some PhD people are using these tools to create soft-processor core architecture perfectly suited·to accelerate motor control algorithms like vectored motor control. It is said that using these tools save months/years of development to people that want to make a core from scratch.
      edited 2009-11-05 18:34
      FredBlais said...
      That is an attractive feature assuming synthesizable compatible verilog exists [noparse]:)[/noparse]
      The tool you mentioned is attractive.
      My laptop got a Windows update last night. I'm having huge problems with that.
      Everything is on hold now. Microsoft really screwed me this time. I'm sure they
      (Posting from reliable Linux today).
      edited 2009-11-05 18:40
      The EULA says that the software is not fit for any purpose or something like that....
      edited 2009-11-05 19:14
      jazzed said...
      http://www.coware.com/PDF/products/ProcessorDesigner.pdf
      I control my windoze updates for that very reason. I only do updates when I don't have something critical happening - been there before. Once with a virus program quarantining wondoze forcing a complete reformat [noparse]:([/noparse]
      Still, it is better than years ago when reformatting every 3 months was mandatory for windoze developers.
