hm55b and propeller
I am having trouble getting some code to work with the compass.
The code works separately but not when I use the compass values to trigger the
conditional statements.
Any ideas??
Code attached. The "compass switch test" inputs through "fullduplexserialplus" one value at a time and triggers the conditional statment.
The "compass switch" uses an input from the compass and the other from "fullduplexseriallplus:. Whether I use CASE or IF statments
it does not work with the compass.
Any ideas??
