Program won't continue past launching a cog
W9GFO
Ok, maybe this is really simple but I don't know why this isn't working. I'm trying out different ways of monitoring buttons. The following code gets stuck launching the cog, it does not proceed to displaying the text on the LCD. The method I want to start in the new cog repeats forever but I expected the program to continue on after launching the cog. If I move the command to display the LCD text above launching the cog, then I see the text - so I know the LCD is working fine. Does the program launched into a new cog affect the main program flow?
Rich H
ButtonTest
ButtonCog
p.s. There are brackets with a "1" and a "2" in them following the last two Button PUBs but they won't show up!?
Rich H
ButtonTest
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
LCD_Pin = 27 ' I/O Pin on ProtoBot For LCD
LCD_Baud = 19_200 ' LCD Baud Rate
LCD_Lines = 4 ' Parallax 4X20 Serial LCD (#27979)
VAR
long Bt1
long Bt2
long Bt3
long stack[noparse][[/noparse]20]
OBJ
LCD : "debug_lcd"
ButtonCog : "ButtonCog"
PUB Init
LCD.init(LCD_Pin, LCD_Baud, LCD_Lines) ' Initialize LCD Object
LCD.cursor(0) ' Turn Off Cursor
LCD.backlight(true) ' Turn On Backlight
LCD.cls
coginit(7, ButtonCog.Start, @stack) '****** Doesn't get past this point
LCD.str(string("Button Test"))
Main
PUB Main
Repeat
Bt1 := ButtonCog.Button1
Bt2 := ButtonCog.Button2
Bt3 := ButtonCog.Button3
debug
PUB debug
LCD.gotoxy(0, 1) ' Position Cursor
LCD.decx(Bt1, 3)
LCD.gotoxy(6, 1)
LCD.decx(Bt2, 3)
LCD.gotoxy(12, 1)
LCD.decx(Bt3, 3) ' Print Fractional Part
ButtonCog
CON
Bt1 = 23
Bt2 = 22
Bt3 = 21
VAR
long Button := 0
PUB Start
ina[noparse][[/noparse]Bt1..Bt3]~
Repeat
repeat while ina[noparse][[/noparse]Bt1..Bt3] == %000 ' stay here until a button is pressed
Button[noparse][[/noparse]0] := 0
Button := 0
Button := 0
if ina[noparse][[/noparse]Bt1] == 1
Button[noparse][[/noparse]0]++
if ina[noparse][[/noparse]Bt2] == 1
Button++
if ina[noparse][[/noparse]Bt3] == 1
Button++
waitcnt(clkfreq/100 +cnt)
PUB Button1 : result
result := Button[noparse][[/noparse]0]
PUB Button2
result := Button
PUB Button3
result := Button
You can't do this. Any method you launch in a cog *must* be in the object you are launching from.
Do it this way.
... and make stack a bit bigger, the extra call uses some more of it.
I'm sure people will also chime in and tell you that coginit is not such a good idea and you'd probably be better off using cognew unless you have a *really* good reason for it.
"VOOM"?!? Mate, this bird wouldn't "voom" if you put four million volts through it! 'E's bleedin' demised!
Ok, I missed that part. Thanks.
No good reason, other than it is shorter and seemingly, easy to understand.
Rich H
Yes, I think it should be.
The same error is in the previous program yet it works fine.
Rich H
Yes, the default is to input so it should work, just pointing it out to help avoid problems elsewhere trying to set input states.
Ok, for normal usecases it's fine to use cognew, but when you run out of COGs you should know which COG can be replaced if needed and then use COGINIT to launch the needed code there. Of course you should be aware of which objects do start their own COG(s). So, for the main program there is no reason not to use COGINIT as long as you know what you are doing.
I'd second your concerns for objects because an object does not know in which environment it's used. So it should NEVER use coginit ... hm ... did I say never? ;o)
