New compiler CRASH!! [FIXED in version 2.00.23] — Parallax Forums
SamTheManSamTheMan Posts: 43
edited 2009-05-11 14:06 in General Discussion
the NEW compiler crash when I try to compile this program:
ID "Mt"
DEVICE SX28, OSCXT2, BOR42
FREQ 20_000_000
STACK 16
'Sio ··PIN ·Rc.2 INPUT··' pull-up via 4.7K
'LcdE ··PIN ·Rc.0 ···' pull-down via 4.7K
'LcdRS ··PIN ·Rc.1
'TRIS_Ctrl ·VAR ·TRIS_c
'LcdBus ··PIN ·RA
'TRIS_Lcd ·VAR ·TRIS_A
'Baud ··CON ·"OT9600" ··' open for single wire
'Cmd ··CON ·$FE ···' LCD command prefix
'serByte ·VAR ·Byte ···' serial IO byte
'tmpB1 ··VAR ·Byte ···' work vars
'tmpB2 ··VAR ·Byte
'tmpW1 ··VAR ·Word
·PROGRAM Start
' Subroutine Declarations
DELAY ··SUB ·1, 2 ···' delay in milliseconds
DELAY_US ·SUB ·1, 2 ···' delay in microseconds
BLIP ··SUB ·0 ···' move bus to/from LCD
LCDINIT ·SUB ·0 ···' initialize LCD
LCDCMD ··SUB ·1 ···' command byte --> LCD
LCDOUT ··SUB ·1 ···' byteVar --> LCD
LCD_PUT··SUB ·1···' byteVar --> LCD
RX_BYTE ·FUNC·1 ···' rx from serial I/O
TX_BYTE ·SUB ·1 ···' tx to serial I/O
' Program Code
Start:
· TRIS_Ctrl = %0100 ····' Rc.2 = input (serial)
· LCDINIT
Main:
· serByte = RX_BYTE ····' wait for byte
· IF serByte = Cmd THEN Do_Command ··' command?
Do_Write:
· LCDOUT serByte ····' no, write char byte
· GOTO Main
Do_Command:
· serByte = RX_BYTE ····' get command byte
· IF serByte = Cmd THEN Extended_Cmd ··' extended command?
· LCDCMD serByte ····' no, write cmd byte
· GOTO Main
Extended_Cmd:
· serByte = RX_BYTE ····' get extended command
Set_IO:
· IF serByte <> $F0 THEN Read_IO ··' check command
· serByte = RX_BYTE ····' get port configuration
· TRIS_IO = serByte ····' setup IO port
· GOTO Main
Read_IO:
· IF serByte <> $F1 THEN Write_IO
· DELAY 2 ·····' delay for host setup
· TX_BYTE IoPort ····' send port bits to host
· GOTO Main
Write_IO:
·IF serByte <> $F2 THEN Read_Byte
· IoPort = RX_BYTE ····' put bits on the port
· GOTO Main
Read_Byte:
· IF serByte <> $FF THEN Cmd_X
· serByte = LCDIN ····' read LCD (cursor pos)
· TX_BYTE serByte ····' send byte to to host
· GOTO Main
Cmd_X: ······' for future expansion
· GOTO Main
' Subroutine Code
' Use: DELAY ms
' -- 'ms' is delay in milliseconds, 1 - 65535
SUB DELAY
· IF __PARAMCNT = 1 THEN
··· tmpW1 = __PARAM1 ····' save byte value
· ELSE
··· tmpW1 = __WPARAM12 ····' save word value
· ENDIF
· PAUSE tmpW1
ENDSUB
' Use: DELAY us
' -- 'us' is delay in microseconds, 1 - 65535
SUB DELAY_US
· ELSE
· ENDIF
· PAUSEUS tmpW1
ENDSUB
' Use: LCDCMD cmdByte
' -- send 'cmdByte' to LCD with RS line low
SUB LCDCMD ·····' write command byte
· LcdRS = 0
· Lcd_Put __PARAM1
ENDSUB
' Use: LCDOUT char
' -- send 'char' to LCD with RS line high
SUB LCDOUT ' write character byte
· LcdRS = 1
· Lcd_Put __PARAM1
ENDSUB __PARAM1
SUB Lcd_Put ·····' byte --> LCD bus
· LcdBus = __PARAM1.high
· BLIP
ENDSUB
SUB BLIP ·····' move bus into LCD
· LcdE = 1
· DELAY_US 2
· LcdE = 0
· DELAY_US 40 ·····' instruction delay
ENDSUB
' Use: char = LCDIN
' -- puts value at LCD cursor position in 'char'
FUNC LCDIN
· TRIS_Lcd = %11111111 ····' make LCD bus inputs
· LcdRS = 1 ·····' character mode
· LcdRW = 1 ·····' read mode
· LcdE = 1 ·····' move byte to bus
· tmpB1 = LcdBus ····' grab the byte
· LcdE = 0 ·····' complete the read
· LcdRW = 0 ·····' return to write mode
· TRIS_Lcd = %00000000 ····' make LCD bus outputs
· RETURN tmpB1 ·····' return byte to caller
ENDFUNC
' Use: LCDINIT
' -- initialize LCD for 8-bit, 2-line interface
SUB LCDINIT:
· DELAY 15 ·····' power-up delay, 15 ms
· TRIS_Lcd = %0000 ····' all outputs
· LcdBus = %0010 ····' 4-bit interface
· BLIP
· DELAY 5 ·····' delay 4.5 ms (min)
· BLIP
· DELAY_US 100
· BLIP
· LCDCMD %00111000 ····' multi-line, 5x7 font
· LCDCMD %00001100 ····' display on, no cursor
· LCDCMD %00000110 ····' auto-increment cursor
· LCDCMD %00000001 ····' clear and home LCD
ENDSUB
' Use: char = RX_BYTE
' -- reads byte from serial input and places in 'char'
FUNC RX_BYTE
· SERIN Sio, Baud, tmpB1 ···' receive a byte
· RETURN tmpB1 ·····' return to caller
ENDFUNC
' Use: TX_BYTE char
' -- transmits 'char' over serial connnection
SUB TX_BYTE
· tmpB1 = __PARAM1 ····' save byte to send
· SEROUT Sio, Baud, tmpB1 ···' send the byte
ENDSUB
Post Edited By Moderator (Bean (Hitt Consulting)) : 5/11/2009 2:10:53 PM GMT
  • JonnyMacJonnyMac Posts: 9,809
    edited 2009-05-11 13:34
    There are all kinds of hosed up bits of code in there -- not sure if that's causing the crash, though.
    It appears that you want a 4-bit LCD interface; is this the case? If yes, I have 4-bit LCD code that I can post (or you can search for it -- it's been posted before) that you can use as a starting point for the project.
  • BeanBean Posts: 8,129
    edited 2009-05-11 13:49
    Okay...I'm on it...
    Bean.
    There is a fine line between arrogance and confidence. Make sure you don't cross it...
    Yep, that was my bad.... Compiled it on a different machine. Should have known better.
    I have posted version 2.00.23
    Sorry about that folks.
    Bean.
