unexpected counter behavior
I set up 4 counters.· 2 counters in the first cog set to count positive edges and two counters in the 2nd cog to generate a signal to count.· I expected the counters to count at the same rate, but the values drift apart.
Could someone take a look and explain why?
loc1 rdlong frqa, m0 ' read latest frequency setpoint rdlong frqb, m1Basically you're using the parameter addresses for the increment value instead of the values stored therein.
