TwinBladeProp - Another SBC (single Board Computer) to run CP/M etc in a box
Cluso99
The TwinBladeProp is a 50mmx79mm (1.96"x3.11") pcb which may arguably be the smallest microcomputer (nanocomputer?) for hobbyists (excluding PDA's and phones). It can be housed in a box 53x82x31mm (translucent blue if I can source enough).
Features:
If you already have a ProtoBoard (or similar), you can add just the self-contained Blade #2 to get your favorite emulation (such as ZiCog for the TriBladeProp) running.
I expect to send the PCB to manufacture Tuesday so I should have everything available in two weeks. For orders etc, please email me cluso@bluemagic.biz
Please do not ask for features (the design is done).
Over the next week I will post schematics, design reasoning, etc. It will be an open design. ·
Hopefully, this should answer some of·the memory questions that have been raging over the past few weeks.
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
· Search the Propeller forums (via Google)
Post Edited (Cluso99) : 5/10/2009 1:12:54 PM GMT
Features:
- Two propeller chips plus
- Internal 5V and 3V3 regulators from user supplied power pack 6-9V
- Built-in propplug circuit to miniUSB (unconfirmed - still trying to squeez it on)
- Second propeller chip (Blade #2) has
- 512KB of static RAM (non-multiplexed)
- microSD socket
- 2 wire (ultra high speed serial) to Blade #1
- No Eeprom (code loaded·from Blade #1)
- Designed to run high speed RAM in applications such as CP/M emulation
- Designed to run the future (PropDos/PropCmd) propeller operating system from microSD
- First propeller chip (Blade #1) has
- Eeprom
- PropPlug interface
- VGA connector
- PS2 connector with keyboard and mouse (or second keyboard)·on the one connector - requires splitter cable from eBay if both required
- AV socket for TV and stereo out (as used in Apple (video) iPods) -requires 3.5mm 4pole cable to 3xRCA connectors from eBay
- 2 wire (ultra high speed serial) to Blade #2
- Loads code from Eeprom into Blade #2 (maybe boot code to microSD)
- Other info
- All ICs are SMT (surface mount)
- PCBs will be available as
- Bare PCB
- PCB with SMT parts assembled (most connectors and associated resistors are t/hole)
- PCB fully assembled
- Other variations
- PCB can be built without Blade #2 in which case the microSD becomes part of Blade #1 (but not SRAM)
- PCB can be built with just Blade #2 and alternative boot Eeprom (Note: not compatable with PropPlug for speed) This would be a self-contained CP/M machine or equivalent, just requiring the Terminal or PC.
·Hopefully, this should answer some of·the memory questions that have been raging over the past few weeks.
bmp
102K
Wait a minute, if it runs Wordstar and SuperCalc surely it would qualify as a Smartphone?
Put me down for a couple of blanks...
tubular
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
For the Blade #2 only version, I will be booting the prop using a small Freescale micro to load it, then booting from microSD.
So I guess what I am saying, I see this as a real computer with an operating system of some kind that will just have minimal boot code to get it started from microSD.
This is the variation on the original SixBlade prop project that I've been waiting for.
Please consider this a request for a circuit board and Blade #2-only pre-mounted circuitry.
Just to be clear, I want to order a circuit board and fully assembled circuitry for Blade #2 only, since I have 6 unused ProtoBoards fresh and waiting for an application.
So, to start with, I'll try my hand with one of my ProtoBoards and your Blade #2 new stuff.
I will send you money as soon as your boards are returned from your PC fab vendor and you have a chance to build the prototypes and figure out costs.
3rd time is a charm, as my rule of thumb on protype variations and experience using the circuits, design principles and hard-won clarity of thought.
Fancy way of saying 3 times is a winner, usually.
You are truly a gentleman and scholar of leisure...
JMH
What would be the approx costings for the above options?
I do not see it as a replacement to the TriBlade, rather a simplified variant that solves issues for the less experienced hobbyists (smt issues). I did however, take the opportunity to refine the SRAM interface. Here's what I have done and why... (see top post for block diagram)
Advantages
Disadvantages
Notes
General
Post Edited (Cluso99) : 5/11/2009 7:08:02 AM GMT
MOVI OUTA, DATA
for writes instead of what I presume might be:
SHL DATA, #24
OR OUTA, DATA
Or such. I'm sure you have thought about this....
One
SHR DATA,#24
and its done!
Sorry, posted the schematic block diagram to the top thread·instead of a bmp [noparse]:([/noparse]
Hope there is room for a blue LED in that translucent blue box[noparse]:)[/noparse]
Now about that Motorola 6809 emulator. Has anyone started on such a thing?
It's a very quite Sunday afternoon here and with a bit of a hangover and I just found myself idly creating a dispatch table for it in the ZiCog framework...
I just discovered that with that it place we could program the Prop using GCC which also has memory bank switching support[noparse]:)[/noparse] Not to mention use FLEX, SKDOS etc etc. AND Ale is busy getting his head around One Man Unix.
MoCog is probably coming...very slowly.
I was kind of wondering. ICC or Catalina for XMM on this board would be great and I'm sure it will happen very soon. They are somewhat hamstrung by having to deal with honking great 32 bit instructions and having to deal with 32 bit wide data all the time when 8 or 16 bits would do. All the while working through an 8 bit data bus. Is it possible that a C compiler producing code for Z80 or whatever 8 bit emulation could actually win in terms of code space and performance for smaller applications?
I like blue leds too
M9Cog (pronounced m(y)'nineCog as in mine) because there is 6800, 68000 etc in motorola's line for operating systems including unix.
I should be catching up with Ross (Catalina) now I am back on the Central Coast.
We should definately use a better 16 bit access and I am sure there is other things we can do to improve performance. But first things first - I need to get CPM3 runing and then getting bank switching. Then we have all CPM things available.... Wordstar, SuperCalc, all sorts of compilers - the TurboPascal was extremely efficient so thats how they made a name for themselves. I don't know performance wise how it would compare to spin - could be a real alternative.
Motorola are going to get very snotty when I draw up the logo for this. At least Zilog no longer use that image I used for ZiCog[noparse]:)[/noparse]
I like the idea of 512KB as it should be enough withot encouraging PC emulation, 8 bit stuff is great for the imagination ie getting around things and milking that last drop of optimization.
Having said that, I never gave the 16 bit instruction of the Z80 the credit they were due, untill I tried to do simular things on AVRs ( got draws full of them, lonely and unused, now the Porp bug has bitten)
--Steve
Bank switched memory gives plenty of working RAM space. But will it fit with RAM layout your programs in ROM are expecting? Do you have the source code to this machine?
The memory mapping is the hard part. The eprom is straight forward, residing from 0000 to DFFF, but for some reason the 8K of ram is addressed as 2 banks of 2K from E800 to EFFF and one 4K bank from F000 to FFFF.
That was the easy part, now there is an additional 14K of ram that is accessed in 256 Byte chunks by block I/O on I/O ports (addresses) 00 to 37. Unfortunately the Z80 puts the port address out on the low 8 bits of the address bus and the byte count on the high 8 bits. This results in the data being scattered through the memory address space. The first byte will be at an address equal to the port number, and each subsequent byte 256 locations higher than the previous one.
When I started I was hoping to use 1 Z80, 1 64K eeprom, 1 32K ram, and a prop to do the serial, clock, address decoding, and glue functions but it seems it is not possible without some additional chips. Not enough I/O pins.
I am hoping to be able to do it with the dual prop/ram and ZiCog. Have you implemented the block I/O instructions?
The SD card is attached to Blade #2 which has to be booted from Blade #1 before the SD card can be accessed. Blade #1 does not have direct access to the SD card ... another reason why it would be good to have some extra EEPROM attached to Blade #1, like using an AT24C1024B instead of a 24C512 or 24LC512.
kwinn: Having the RAM in non continuous lumps should not be a problem. Having extra RAM in the "holes" should not hurt. If it does we can puts tests for the "holes" in the emulation at the risk of a little slow down.
I'm interested in your next statements about how the Z80 "puts port the address out on the low 8 bits of the address bus and the byte count on the high 8 bits"
The Z80 hardware, as far as I can tell, does this during block I/O operations: The 16 bit HL register is the source/destination in memory space. The 8 bit C register is the port number in I/O space and the 8 bit B register is the current byte count value. Now HL goes out on the address bus for the memory read/write. C goes out on the low address pins as the port number during I/O read/write. B goes out on the hight address pins during read/write also. (This is undocumented behavior).
Now don't forget that during the I/O phase the bus is indicating an IO operation not a memory space operation. So it is possible hang up to 64K of RAM on the bus in I/O space not normal memory space.
What I suspect is happening is that during a block I/O your system is decoding the low address bits (from reg C) to select a particular 256 byte block of RAM in the I/O map. It then uses the high address bits (from the counter
Of course it makes no difference if the low and high are not swapped. Just means the bytes are scrambled in their RAM positions but who cares.
I'm very sure we could tweak the ZiCog I/O and memory handling a little to do this trick.
Actually no, I have not implemented the block I/O yet.
I'm assuming (wrongly perhaps) that the optional "Single Chip Prop Bootloader" takes the place of Blade #1. It certain takes its place functionally.
Not sure but I think the idea is that it can be used as such with Blade #1 is in place or not. Sounds kind of neat. Cluso will elaborate I'm sure.
I like the cunning way you are loading the data off blade #1's eeprom.
I'm thinking you would always need blade #1 in some way, even if you didn't have a keyboard and a vga display you still need some sort of input/output.
Re things we have and things we would like, you could add C to the list of things we have. BDS C is a proper structured language available about 3/4 the way down the page http://www.schorn.ch/cpm/intro.php and the manual etc is at http://www.bdsoft.com/resources/bdsc.html
Can you please put me down for an assembled board?
Post Edited (Dr_Acula (James Moxham)) : 5/11/2009 12:54:26 AM GMT
Mike etc: An AT24C1024 can be fitted instead of the AT24C512 on Blade #1.
Blade #1 actually can access the microSD but beware of conflicts - so Blade #1 can hold Blade #2 in reset. Alternately, the Single Chip bootloader can also be fitted. The TriBlade was designed to load Blades #1 & #3 from Blade #2 (just haven't had the time to do the code).
Nothing has been prototyped - After 40 years of designs, I don't do this. The TriBlade was built without prototyping. I designed the TriBlade while waiting for the SixBlade pcb so I never built the SixBlade. Almost all of my commercial designs have been first revision (A) boards.
This is still a hobby for me, but who knows..
Here is a photo of the box and one of my previous designs showing how the box was laser cut and printed.
Post Edited (Cluso99) : 5/11/2009 2:53:28 AM GMT
That's an impressive record Cluso. Never seen anything like it in my dealings with hardware designs/designers.
I used that same box for an AVR project. About the neatest thing I ever made at home. I love it.
I've already been running BDSC compiled programs on PropAltair.
--Steve
