TSL230 issues — Parallax Forums
TSL230 issues
skynuggetskynugget Posts: 172
edited 2009-05-11 22:11 in General Discussion
hey all im playing with a tsl230 light to frequency converter on an sx28. With the following code, my output is not the same as if i where to use the stock demo code for the bs2. im just testing with the sensitivity disabled for now. When i run the following sx/b code, the value of reading increments by a value of 256.. ie 0 256 512 768 ....... running the bs2 code i have a value of 80 (in my current light conditions) on the sx28 its sitting at 0 until flash a light on it. any ideas? thanks in advace!!
sx/b 2.0 code:
DEVICE          SX28, OSCXT2, BOR42
FREQ            4_000_000
STACK           16
TSL230                pin        RA.2 input
tmpw1                 var         word
reading                 var         word
GET_LIGHT            func        2    word
PROGRAM Start
Start:
     reading = get_light
    WATCH reading, 16, udec
    BREAK
GOTO start
func GET_LIGHT
    tmpW1 = 0
    count TSL230, 200, tmpw1
    return tmpw1
endfunc
  • ZootZoot Posts: 2,227
    edited 2009-05-10 16:08
    The Stamp demo uses a 100ms measuring period for COUNT, not 200ms. Could that be it? The only other thing might be if you have the enable/sensitivity pins wired differently when you moved it to your SX project board. Grasping a bit at straws here...
  • skynuggetskynugget Posts: 172
    edited 2009-05-10 17:22
    hey zoot, i tried it with 100ms and it exhibited even more weird (really didnt work at all). So i figured the sx was sweeping it to fast or something. im using a PDB with a stamp and an sx in it running at the same time... im just moving one wire to test.
    does COUNT work differently in SX/B then in stamp basic?
  • BeanBean Posts: 8,129
    edited 2009-05-10 20:50
    Skynugget,
    · I had a look at the compiled code, and there is a bug in the COUNT command.
    · I will post a corrected version of the compiler tomorrow.
    · Thanks for catching that...
    Bean.
    There is a fine line between arrogance and confidence. Make sure you don't cross it...
    Post Edited (Bean (Hitt Consulting)) : 5/10/2009 9:03:02 PM GMT
    edited 2009-05-10 21:06
    WoW i caught a bug!!! I'm somebody now! thanks for checking it out bean.
  • Shawn LoweShawn Lowe Posts: 635
    edited 2009-05-11 04:30
    LOL! Good one skynugget!
    Shawn Lowe
    When all else fails.....procrastinate!
    edited 2009-05-11 11:10
    skynugget,
    · I have posted version 2.00.23 of the compiler.·http://forums.parallax.com/attachment.php?attachmentid=0
    · This should fix the bug you found.
    · Thanks again for your post. It is users like you who make the compiler a better product.
    · Let us know if it works now.
    Bean.
    Post Edited (Bean (Hitt Consulting)) : 5/11/2009 2:09:43 PM GMT
    Thanks Bean, Its Fixed!!!
    For anyone else check the sx2.0 thread, the link posted above no longer works cause Bean fixes so much stuff so fast:
    http://forums.parallax.com/forums/default.aspx?f=7&m=323767
    Post Edited (skynugget) : 5/12/2009 12:18:57 AM GMT
