SERIN on SIN
Good Afternoon everyone,
I am trying to talk from one stamp on the PDB through the level shifter to another stamp on a seperate board through the programing port.· I can command the seperate board no problem using the debug window, but when I try to command it from the stamp on the PDB through the level shifter I get nothing.· I have scoped both transmissions; the timing and·levels ·of both transmissions are identical.· Any sugestions?
There are 10 types of people that understand binary, those who do, and those who don't.
'File:Relay_Test_Slave 'Date:31MAR09 ' {$STAMP BS2} ' {$PBASIC 2.5} '-----Program Description--------------------------------------------------------------------- '-----Pin Declarations------------------------------------------------------------------------ '-----Variables------------------------------------------------------------------------------- relay VAR Byte '-----Constants------------------------------------------------------------------------------- Baud CON $4054 'Baud CON 84 TimeOut CON 2000 Rx CON 16 Tx CON 16 '-----EEPROM Data----------------------------------------------------------------------------- '-----Initialization-------------------------------------------------------------------------- OUTH = %00000000 DIRH = %11111111 '-----Program--------------------------------------------------------------------------------- Main: DO SERIN Rx, Baud, TimeOut, Blink, [noparse][[/noparse]DEC4 relay] SEROUT Tx, Baud, [noparse][[/noparse]DEC5 relay] OUTH = ~relay LOOP '-----Subroutines----------------------------------------------------------------------------- Blink: 'OUTH = $10 'PAUSE 200 'OUTH = $00 GOTO Main
'File:Relay_Test_Master 'Author: 'Date: ' {$STAMP BS2} ' {$PBASIC 2.5} '-----Program Description--------------------------------------------------------------------- Rx PIN 0 Tx PIN 1 '-----Pin Declarations------------------------------------------------------------------------ '-----Variables------------------------------------------------------------------------------- celsius VAR Word relay VAR Byte repeat VAR Word '-----Constants------------------------------------------------------------------------------- 'Baud CON $4054 Baud CON 84 TimeOut CON 2000 EndL CON 10 '-----EEPROM Data----------------------------------------------------------------------------- '-----Initialization-------------------------------------------------------------------------- relay = 0 DIRL = %00000011 '-----Program--------------------------------------------------------------------------------- DO SEROUT Tx, Baud, [noparse][[/noparse]$35, CR] PAUSE 1000 LOOP
I believe I have already tried using 84 for both units and still nothing.· I will try again though to double check, and let you know.· Won't be until Monday though.· Thanks again.
