Help Needed about Ping Ultrasonic
Hello everyone,
I have already search thie forum and google it but I do not find the answer.
I am using Ping Ultrasonic sensor(three Pins)
I try to use 7 ultrasonics at the same time. Is it possible?
I am using PIC 16F877 microcontroller and 2840 development board from Basic Micro.
I can use one Ping Ultrasonic. It is work perfectly but how to use 7 Pings at the same time or one by one?
I mean that I use timer1 to count the time (how long the echo come back)and to caculate the distance by echo.
Since same pin is used to transmit and recieve a signal, I need to keep firing and receiving.
There are 7 Ping Ultrasonics but I do not have 7 timers so how should I do ?
Or, how can I change a pin one by one?
Your help will be appreciated.
2) Each Ping is attached to a different I/O pin. You will need a subroutine for each one that sets the I/O pin to output, generates the trigger pulse, sets the I/O pin to input, initializes the timer to count down (or up), waits for the leading edge of the pulse from the Ping, starts the timer, waits for the trailing edge of the pulse, reads the timer value, and disables the timer.
This is not a PIC support forum, so you are unlikely to get much help in specifically writing the PIC code, but the same general principles apply whether you use a PIC or a Propeller or an SX to control a bunch of Pings.
Parallax Engineering
I had honestly considered using multiple PING units for a musical
instrument before reading this. I've noticed in my travels to Parallax
they have a robot which is using three pings. (granted pointed
about 20-30 degrees in different directions)
The signal that comes from the PING is audio/ultrasonic?
Is there another way to use multiple PINGS next to each other or
should I be looking into another sensor.
I was originally envisioning PING sensors about 3 inches apart,
each facing upward. Sounds like this won't work.
OBC
New to the Propeller?
You've put that project back on the immediate list! Thank you!
OBC
