outputting a signal to an esc for a brushless motor — Parallax Forums
science_geekscience_geek Posts: 247
edited 2009-05-08 15:42 in General Discussion
i have a brushless motor and an esc for it. i need to first controll it with a basic stamp and then when thats working i need to move on to a propellor. from my understanding, an esc is just like a servo, you send a series of pulses and it rotates, is this the same for esc's or is it a different signal, would pulsout command for the bs2 work, also would something from obex like the pwm drivers work with the prop to drive it.
  • LeonLeon Posts: 7,620
    edited 2009-05-08 12:19
    Controller data sheet?
    You could use a Propeller as a BLDC motor controller, of course, with a few other components.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Post Edited (Leon) : 5/8/2009 12:44:28 PM GMT
  • W9GFOW9GFO Posts: 4,010
    An ESC like used in RC cars, planes etc. is designed to use the same signals as servos. So yes, pulsout should work fine. For the Propeller you could use the Servo32 object.
    Rich H
