Propeller Problem reading RC Controller input
Greetings,
I am attempting to read the input with an RC controller , Futaba FP-R127DF, It is being paired with the Skysport 4 Radio Transmitter. I am using a hexapod crawler, which is able to walk fine on its on using 3 servos. I am trying to use the propeller to interpret commands sent to the RC unit and in turn have the the propeller sned more advanced commands to the hexapod. I am using the prop education kit set up on the the bot. I am currently using the BS2 Object to send commands to the servos. I have attached what I currently have done, I believe there is something wrong with how my prop is reading the servo output. Thanks for any help that anyone can provide.
forwardOrBack := 1 should be long[noparse][[/noparse]forwardOrBack] := 1
I haven't used it but an object to read RC input is here
http://forums.parallax.com/forums/default.aspx?f=25&m=231689&p=1&ord=d
John Abshier
Jason
