Optimize cog for my application
micman2
Hi all, sorry for my English
I do building the special robot for Disability.
In hardware I have 2 wheels and two motor with encoder and 1 joystick :
I would control the system with propeller controller, I like propeller
The function :
- Read 2 encoder
- 2 PWM for motor
- 2 PID for control motor velocity and acceleration & decelleration
- 1 serial (I would apply the "easy bluetooth" see in parallax components)
- 1 SPI slave for future control with another uC
- 1 joystick
My problem is how to optimize the task of cog.
I thought of doing this :
1- cog for read 1 encoder left
1- cog for read 1 encoder right
1- cog generate pwm for motor left
1- cog generate pwm for motor right
1- cog for control velocity (PID) and acceleration&deceleration
1- cog for serial TX/RX
1- cog for SPI slave
1- cog for Main which manages all the system (read joystick send velocity in the PID read SPI, Serial and executes the commands)
8 cog!
Is too expensive so? I can optimize some function?
Michele
The function :
- Read 2 encoder
- 2 PWM for motor
- 1 joystick
8 cog!
Michele
The rest depends on the needs. What is the serial interface used for? What is the SPI slave used for? Do you expect to receive/send data on both interfaces on the same time?
In your current situation there·is only·a minor reason to optimize for COG usage: power consumption
On the other hand - doing more than only one thing in one COG is a bit more complicated. If you have a look at the FullSerialDuplex object you can see what I mean. So, if you don't figure out how to code reading the joystick and read the encoders, then do it in 2 COGs.
But it might be that your project goes in a direction where you attach additional devices to it and every free COG will be welcome.
Post Edited (MagIO2) : 5/7/2009 9:31:55 AM GMT
