BS2 burning out?
Hello All,
I have a stamp in class board with the four servo outputs.
I'm running 3 servos - the program works as planned.
However, when I put one of the servos under load - drives a little car, the servo stops running (will pulse when I re-power the board).
I believe I burned out the BS2.
But, now the BS2 won't be recognized when I try to re-program it, and when the I touched one of the small chips on it's board (maybe the interpreter chip) it was too hot to touch.
How did I manage to lose the BS2? Isn't the BS2 isolated from the servo?
Any advice would be appreciated.
Shmow
Shmow
Kind regards,
Dave
Dave Andreae
Parallax Tech Support·
Thanks for the reply.
I have the power supply I purchased from Parallax .
The other circuits or loads are an EMIC and an IR receiver.
I’m not sure I the BS2 became damaged.
Everything worked prior the putting the servo under load.
What do you think?
John-Mark Lyons
- Stephen
Dave
Dave Andreae
good point; fortunately, none of those outputs were sharing those pins.
Shmow
