USB2SER question
I bought the USB2SER module to interface with my BS2 stamps and it works well.
I also tried to use it to connect to a Scott Edwards serial LCD (BPP-420L) which accepts TTL or RS232 signals.
The LCD displays garbage.
After searching the forums, it appears that the USB2SER outputs 3.3v rather than 5v TTL.
I am assuming that the LCD module needs a 5v signal to function (the LCD works fine usign the BS2 serout or using +/-12v from a PC serial port).
Does anyone have a different opinion on why the USB2SER will not drive the BPP-420L LCD?
Thanks!
Thanks!
The BASIC Stamp outputs a TTL level signal, so that would explain why the display would operate properly directly from the BASIC Stamp; looking at the manual of the BPP-420L is states TTL/CMOS can be used. Have you confirmed the inverted baud rate, 9600 or 2400 that is being used?
Snippet from the manual for the BPP-420:
Power requirements (BL off).................................4.8 to 5.5 Vdc @ 10mA
Power requirements (BL on)...............................4.8 to 5.5 Vdc @ 100mA
User connector .....................5-pin header; 0.025" posts on 0.10" centers
Connector pinout....................................................+5 GND SER GND +5
Serial input...............RS-232, or inverted TTL/CMOS, 9600 or 2400, N81
Buzzer output .............5V @ 25mA max; pulses approx. 100ms for BELL
Operating temperature.......................................0° to 50°C (32° to 122°F)
Serial data rates ............................................................2400 or 9600 bps
Respectfully,
Joshua Donelson
www.parallax.com
Post Edited (Joshua Donelson (Parallax)) : 5/7/2009 4:12:47 PM GMT
Thanks for your response.
When I use the BS2 to drive the BPP-420 LCD·I use inverted 9600 (mode 16468).
The piggyback board on the LCD also lets you directly connect to standard PC·RS232 port (+12v/-12v) using the same connection (no line driver needed).
Both of those scenarios work fine.
Trying to use the USB2SER board does not work though. I imagine that the LCD needs a 5v TTL TX signal but the USB2SER is a 3.3v signal.
- Ron Czapala
Parallax Engineering
· The Seetron BPP-420 has three connection pins:· ground, +5v, and serial signal.
When I use a basic stamp to drive the LCD, ·I use inverted 9600 mode, but curiously the LCD also works when I directly connect the LCD's serial connection to my PC's DB9 serial port (pin 3). I use a vbscript program and MSCommLib.MSComm ActiveX control·(see code·below).
There is no inverted option on a standard PC RS232 port, correct?
The BPP420 somehow handles both the BS2 TTL inverted signal and also a direct RS232 serial connection on pin3 on the same wire.
I also have a Matrix Orbital LK204-25-WB (with onboard DB9) and it also displays garbage when I try to use the USB2SER module.
NOTE: I use a MAX233a when·connecting the LK204-25 to the Basic Stamp (non-inverted).
Since both displays work with the basic stamp 5v signal and neither work with USB2SER 3.3v, it seems like the voltage difference is the problem
Confusing...
-Ron
··· MSComm1.CommPort = comPort
··· MSComm1.DTREnable = False
··· MSComm1.EOFEnable = False
··· MSComm1.Handshaking = comNone
··· MSComm1.InBufferSize = 1024
··· MSComm1.InputLen = 0··
··· MSComm1.InputMode = comInputModeText
··· MSComm1.NullDiscard = False
··· MSComm1.ParityReplace = "?"
··· MSComm1.RThreshold = 1
··· MSComm1.RTSEnable = False
··· MSComm1.SThreshold = 0
··· MSComm1.Settings = "9600,n,8,1"
··· On Error Resume Next
··· MSComm1.PortOpen = True
It sounds like you are using multiple devices; can you please verify exactly what it is you are using?·Also, what controller you are trying to use also?
Respectfully,
Joshua Donelson
www.parallax.com
I've basically been trying to get the USB2SER module to directly drive either of my LCD displays: Scott Edwards BPP-420L
or Matrix Orbital LK204-25-WB (with serial DB9 onboard) - no Basic Stamp.
The USB2Ser works fine with BS2 and BS2P stamps.
And the LCDs also work with the Basic Stamps:· BPP-420L (9600 inverted)·and LK204-25 (using MAX233a line driver·9600 non-inverted).
It is not a big issue, but it seems that the USB2SER·outputs 3.3v - sufficient for basic stamps but not for my LCDs expecting a 5v signal.
Anway, thanks for your responses. Maybe this thread will be helpful to people who are considering the USB2SER for driving devices other than microcontrollers...
- Ron
