9V Supply for Propeller kit
The Propeller Education Kit comes with a 9V battery connector. But I'm burning through battery after battery with all the testing and diagnostics that I'm doing with my project. Is it safe to substitute a plug-in 9V power supply (wall wart?) instead of using batteries? Any particular cautions I'd need to take?
Yes Roger by all means, move to a steady power supply, especially for testing and debugging.· 9V are notoriously low in the amount of mAH that they can pack.· On average this is about 400mA, but I have seen their rating as low as 150mA.· So a Propeller requiring·100mA with a 400mAH pack would only give you about 4 hours.· If you want to go with batteries, use a 4 pack of AA's feeding the 3.3V regulator, or a 6 pack of AA's feeding the 5V regulator.· Using the AA's would give you roughly 5 to 6 times the run-time as a single 9V battery.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 5/6/2009 5:05:32 AM GMT
One word of caution, however: other components you place on your breadboard might not respond to a wall wart as well as the Propeller. I never figured out why, but a Real Time CLock I had on the same board was never able to keep time when using a wall wart - the seconds would always get messed up on power up.
I hope that helps. More experienced people here on the forum might have other tips, too. For example, depending on what you're running all at once, you might want to check that your wall wart can give you all the current you need.
good luck,
Mark
I've always been confused about this - If I run a 9V battery thru a 3.3v regulator that's attached to a 100mA load, how many watts does the regulator dissipate / how long will my 9v battery last?
Gadget Gangster - Share your Electronic Projects - Sign up as a Designer and get a free 4-pack of Project Boards!
How long it lasts would depend on the mAhr rating. For a best case scenario a battery with a 500 mAhr rating and the linear regulator circuit would last 5 hours. The switching regulator would increase that to 15 hours.
Make sure the polarity is correct. If you don't know what this means, ask someone in your neighborhood who knows to help you.
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
OK, I guess that makes sense. But then why would the 15V unit measure at 15V and the 9V battery measure at 9V? If the ratings are for "under load" then shouldn't all of them measure high when just being measured by a voltmeter?
Yup, that much I can handle. [noparse]:)[/noparse]
Glad you're ok with polarity. Many people north of me on the peninsula are really confused with that [noparse]:)[/noparse]
--Steve
When the supply is loaded the losses through the transformer and bridge increase and the smoothing becomes laboured and the output volage is reduced, ultimatly arriving at the quoted voltage at the quoted current. They are usually bloody hot at this point which eventually dries out the capacitor. A lot of them use the frail wiring of the primary as both the current and thermal fuse.
The only answer to these problems are to build heavier rated supplies with regulation, not so cheap or small or so easy to get in the Pound/Dollar Shop.
Batteries generate their volts from chemical reactions and are better on regulation, depending on which chemistry. Cheap old Zinc_Carbon exaust and give poor regulation quickly. Better batteries give better performance at a cost. To use a small 9V battery to drop straight down to 3V if throwing away most of its stored energy, which cost you money. On my boards ( home made Demos) I have used 5 Volt regulators (which req 2Volts headroom) feeding the 3.3V reg. This means that 7 Volts is the minimum that can be used but if the 5V rail could be ditched then 3.3V (+1V headroom) then 4.5V could be used ie just 3 x AA cells which would give about 5+ times the Amp-Hourage of dinky 9V. Not so cute/convinient though.
I must confess to hating cheap PSUs and batteries as I an fortunate to get/recycle/repair Switch mode PSUs and lithium cells free.
--Steve
--Steve
I use a 6 volts 1500ma supply, it is rock solid and the 5 volt REG is cool, 7.5 V might be a better choice if the supply cannot source 1 amp without ripple.
Works for me.
I like the results of bad PSUs, the proceeds feed the family.
