Power Filtering
James Long
Since I'm not the best designer in the world, I would like to ask a pretty simple question.
I'm trying to power a pcb from a 12 volt system with a permanent magnet alternator. I'm worried about noise from the alternator.
With using a switching regulator, what should I include to filter noise from the system.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
James L
James L
Partner/Designer
If I put one on the PCB, how would I size the inductor? Amperage??
James L
James L
Partner/Designer
Anyone have any great suggestions as to the best method to do so?
I was looking at a buck regulator, but the parts are huge. I really wanted to keep the power supply part of the board small, if possible. It may not be so.......
James L
James L
Partner/Designer
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I think I found a solution. Although maybe not the best, I'm going with an Artesyn Technologies LDO03C
I can adjust it to 5 volts, and it is a buck dc to dc converter. It's a little pricey, but saves me the time to design the regulator into the board.
James L
James L
Partner/Designer
Leon
