Digital to Analog Converter
I am using a BS2 and a AD694AQ to try an create a 4-20mA signal.· For the life of me I cannot get this to work.· After looking at the datasheets and trying many setups its obvious Im not doing this right.· Also this DAC does not use an 8 bit input pin system so Im not sure how to adjust the output.· Can anyone suggest a simple setup to for this IC and how·to adjust the output·up and down?· Thank you so much for any help.
Use the PWMOUT (with the resistor and capacitor) command as shown in the Help files to generate a voltage you can control.
Cheers,
Tom Sisk
http://www.siskconsult.com
Always assume the manufacturer knows how to use the chip!
Cheers,
Tom Sisk
