Servo Controller battery power supply
Okay, I promise that I used the search engine first to look for answers to this question...
I've been learning to use servos and servo controllers, always using a wall wart power supply for both servo power and controller power. I'd like to learn how to use a battery power supply. I bought a 7.2V NiCad pack,and then noticed that the servos I'm using say that 6V is the max. I built a little adjustable power supply to bring it down a little under 6V using a LM 317, but under load it drops down to something like 2.5V, and of course at that voltage doesn't drive the servos. It drops down to that point even when I just turn on the servo controller (Parallax Serial Servo Controller) without any servos attached.
I see in an earlier (2005) thread that Ken Gracey suggested that one can just use a 7.2V battery pack directly into the servo power inputs, and the documentation for the servo controller shows that as well. But that's 7.2V, over the 6V max on the servos' instructions. In addition, I'm actually getting a little over 7.2V, and the documentation says "7.5V max" for that input.
Am I going to fry my servos if I use a 7.2V NiCad pack?
Am I going to fry my controller if that pack is actually putting out (say) 7.85V?
And while we're at it, am I right in assuming that the reason my little LM 317 power supply's voltage drops so dramatically is that I'm trying to draw far too much current through it?
If the 7.2V pack can't be used directly, is there a better voltage regulator/power supply circuit I could use to provide adequate voltage and current using that 7.2V NiCad pack?
I'd post a picture but my pack is zip-tied in my ProtoBot (Propeller Protoboard BoeBOT)
Rich H
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=LM1085IT-5.0-ND
(though I might have to replace the capacitors as well). Is that reasonable?
I'd rather not hack apart the battery pack - I'd buy a 6V version instead before doing that. I can certainly make other use of this 7.2V pack.
