Lcd Help
A while ago, I purchased a set of 5 LCD Displays from American Science and Surplus
· Some of the pins were bent and I fixed 'em, but I need some info on these LCDs. I tried looking up info from the manufacturer, which was Planar Systems and Standish. I need some info or datasheets for:
Standish 9310428436542001
Planar 0038-4206-363-440-01
Planar 0102-3970-363-420-01
Post Edited (Fwiss) : 5/5/2009 11:02:52 AM GMT
Rick
These are called Field-Effect Displays…they are LCD, but they required a driver IC to run them generally. Each element of the display is broken down into row/column matrices and needs to be energized to display that segment. This would require too many I/O pins from a typical microcontroller. You can either use an expander and try to drive them directly, or you can find a driver IC. I know Jameco used to carry one for driving Field-Effect LCD displays. Take care.
Parallax Engineering
I can't find a driver...
Is there another name for these types?
Post Edited (Fwiss) : 5/5/2009 10:07:59 PM GMT
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?jameco_page=46&langId=-1&productId=17110&drill_parents=category_root%24%2440%24%244050&drill_children=40%24%244050%24%24405010&catalogId=10001&storeId=10001&search_type=all&drill_displays=LCD+Products+%2F+Field+Effect+%2F+4+Digits&ddkey=http:ParametricSearchResultsView
This link should (hopefully) get you the ICs that drive these displays...
http://www.jameco.com/webapp/wcs/stores/servlet/ParametricSearchResultsView?langId=-1&storeId=10001&catalogId=10001&jameco_page=46&drill_parents=category_root%24%2410%24%241035&drill_children=10%24%241035%24%24103525&drill_displays=ICs%20%26%20Semiconductors%20%2F%20Interface%20%2F%20Display%20Drivers
