Motor Mount & Wheel Kit (27971) controller pins to USB port
I have another question about the Motor Mount & Wheel Kit with Position Controller (27971).
On the Position Controller the pins to connect to a controller contain GND, +5VDC, and DATA.· I want to control this with a Via EPIA Nano ITX board which does not have any standard serial Com ports, only USB ports.· I’m assuming I need some kind of USB to serial converter product.
I was looking at USBIO24 R Digital I/O Module from Elexol at http://www.elexol.com/IO_Modules/USB_IO_24.php
But the reseller wasn’t sure if it would be fast enough.· I also looked at USB to TTL 72in Serial Converter Cable from SuperDroid at http://www.superdroidrobots.com/shop/item.asp?itemid=795&catid=57 but it uses full TTL communications and I don’t think that is what I need.
Does anyone have any suggestions for getting this data in and out of my USB port(s)?
Dogulas
Dogulas
Most USB to serial adapters are RS-232 compatible on the device side. The main problem is that you need non-inverted TTL compatible signals and they need to be on a single I/O pin at the other end. There are circuits that demonstrate this at the following link. I hope this helps. Take care.
http://forums.parallax.com/showthread.php?p=640507
Parallax Engineering
Dogulas
